rnln's Avatar
question: oil cooler/fan for slantnose
I need an oil cooler, summer is comming. Normal drive then I don't, but when trafic jam comes, I think I do.
The problem is that my car is a slantnose conversion, the front fender only can fit a small cooler as 1/2 your size. I don't want to fit one up front because I don't want to cut/weld and too much conversion to the car. Also my front is way too lowed. It also has the AC condensor up in place already.
The only place I can think of is the rear fender, right behind the grill/port. Has anyone done so? Do you get after market cooler for it or you shread out $$$ for the original equipment?
Thanks.
Fat butt 911, 1987
Old 04-29-2006, 09:20 AM
IMO, a cooler up front will be more effective, easier to install and less $$$. There is no cutting or welding required. You can use hard or flex lines to extend the reach of your factory lines. I believe Chuck Moreland has a well regarded kit on his ElaphantRacing.com site. If your A/C components are factory you should have no problem at all.
A member here does offer a kit for the rear brake vent cooler/fan setup...I think it may be Keith Epperley (sp).
A search will get more info.....
Warren & Ron, may you rest in Peace.
Old 04-29-2006, 10:01 AM
rnln's Avatar
Hi Rick,
How do you do yours? Please post some pics if possible.
When I look under my car, I can see no place to install it. Then probably my ac condensor is not stock?
You mentioned Keith Epperley, what is his pelican name?
Thanks.
Fat butt 911, 1987
Old 04-30-2006, 03:23 AM
