windshield seal replacement
how difficult is it to replace a windshield seal on a 77 911s and what can replace the metal strip and what replaces that....i got a leak......Thanks
1977 Porsche 911S (Widebody) |
Windshield is easy, the search feature will give you a ton of info. The metal seal gets inserted before you mount the windshield. There is a later year seal that doesn't require the metal but I can't ever remember what it is. Copy and past this for your sort. http://forums.pelicanparts.com/search.php?action=showresults&searchid=1873149&sortby=lastpost&sortorder=descending
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
I believe the later year seal is the 964? I think you can use the 964 seal with the existing windshield but I've heard if you want to use the 964 seal on the back window you have to change to the 964 glass.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
some related info here:
New windshield- 911 or 964 seal?
Fat butt 911, 1987 |
I just replaced my front windshield this weekend with one from PPG. I decided not to use the metal trim and instead used some #8 black coated electrical wire from Home Depot. Another Pelicanite suggested this in an ealier thread. It worked well and I like the look. Had my wife pulling the string while my daughter and I held the windshield in place. Use two wraps of the string in case you miss a spot as you come around. I'll try to post a picture tonight.
Robert Williams 70' 911T Last edited by rw7810; 04-11-2006 at 05:55 AM.. |
can you post a photo of the final product?
Hope these come through OK
![]() ![]() PS: The windshield was about $124.00 from Safelite, PPG brand.
Robert Williams 70' 911T Last edited by rw7810; 04-11-2006 at 06:07 PM.. |
Air Medal or two
just bring it over/ will have it done in 20 min
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
George i love your enthusiasm,but i rather you have your car finished or shall i say up and running before working on mine....also since the leather on my dash has shrunk,i want to wait and figure out that dilemma,and im totally lost with that .
Air Medal or two
replace the dash while windshield is out....cut your old seal, remove the glass, remove the dash . replace dash..when you ready I will come over and help you pop the new glass in
rw7810,
Did you use anything special to put the #8 gauge wire in? i as well have no trim as the folks who replaced my seal were idiots.. As i can't install the trim now, I went to purchase the wire, but it doesn't seem to want to stay in place. Did you lube it at all?
1987 930 1956 Chevy 3100 2009 Subaru Forester 2003 KX250 X2(I like my toys!!) |
Air Medal or two
Ace sells 3/32 brass stuff,works real well,just shove it in
I used some "wire pulling lube" and a screen spline roller to push the wire in to the trim slot.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
I'll give that a whirl.
Slumlord
Mark - Let me know how it goes, I'm doing mine also.
I have wire lube (I'm near the airport) if you need some.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Where would I find wire lube? I purchased the #8 wire last night, and couldn't really put much time into it, but I did spend about 10 minutes trying, with no success. I plan to try it today/this evening.
I'm in the beaches.
Slumlord
Read the post above and PM me.
Didn't even bother putting anything into the groove where the metal strip goes. Looks better IMO without it and no leaks at six months.
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
It's not so much the leaks I am worried about as it does nto leak right now. It's more that I don't want any water to accumulate in the frame area and start to promote rust.
I have used vacuum line in place of the trim with much success on two windshields, it goes in real easy with a bit of dish soap and once its in it looks fantastic. Also keep in mind guys that the purpose of the aluminium trim in the first place is to keep pressure on the walls of the seal groove acting as a lock strip so it is probably not a good idea to leave the groove empty.
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
