Guest
Posts: n/a
Ign. Switch Removal
How that hell do you get the thing out.
I removed the nut and stud at the steering wheel, but that was no help. Spec. tool at the switch plate? Signed, dumb ass |
Hilbilly Deluxe
And your car is a...........?
Guest
Posts: n/a
Sorry, 1981 911 sc
Wer bremst verliert
Huh?
move your seat all the way back and get your shoulders on the floor, looking up at the switch from behind the dash. The wiring harness pulls !!!Gently!!! back from it. Not sure what you're doing in the steering wheel....
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Hilbilly Deluxe
You mean the electrical portion, or the lock itself?
The electrical part screws on the back of the lock cylinder. Some claim to have swapped the electrical part without removing the lock, but I couldn't do it. To remove the lock assembly, you need to drill out the 2 headless screws under the cover around the key. Be very gentle, there are some electrical connections in there. Tom |
Guest
Posts: n/a
Oh what a pain, I can almost reach the top most screw on the elec. mod.
I am going to Sears now to see if I can find a flexable screwdriver. |
pick up some metric magic while you are there. LOL
1973.5 911t |
Replacement Screws
Pablo,
It would take a lot of patience and dexterity to remove the 2 screws that hold the ignition switch. The space is so tight and after successfully removing the 2 screws, I would recommend that you replace them with allen type head scews. Installation will be a lot easier. Good luck. Tony |
