-   -   Clock Delete for Gauges + (http://forums.pelicanparts.com/porsche-911-technical-forum/276356-clock-delete-gauges.html)
greglepore 04-10-2006 07:55 AM
I recently mounted a 2 1/16 VDO gauge (mine is boost) in the clock space using an adaptor cut from MDF and painted flat black. I'm also going to add a single LED voltage monitor :
http://www.signaldynamics.com/products/Modules/HUVM.asp
to the plug.
Given that it turns out that I have the hole saws to do this very easily, I'd be willing to make a small run of them for Pelicans. If there is enough interest, I could also do them for 2.5 in gauges as well. I'm thinking 15 bucks each. I can bring a few to Hershey if there is any interest.
They do require a couple wraps of electrical tape around the invisible portion of the gasket for a secure fit, but you don't see it if done carefully and its very secure.
I searched the online catalog here and didn't see anything, but if this conflicts with anything Pelican is doing, please delete.
DW SD 04-10-2006 09:05 AM
Greg,
GREAT Idea! I like the voltage LED light.
Doug
