rear wheels spin when in neutral
This is probably a stupid question, but I started my car while on jackstands and the rear wheels spin very slowly when the transmission is in neutral. Normal?
'82 911SC racecar '05 WRX STi |
Yep, perfectly normal. This is basically bearing drag that tends to rotate the gearbox. One can stop the rotation by hand, if so desired.
Thank you sir!
Cheers, Jeff
