Rouxzy's Avatar
Oil thermstat
I've been having problems with my engine running warmer than normally and was wondering if the oil was getting to the front oil cooler as it should. So I removed the side cap from the side of the thermostat and took out the spring and plunger. But before I could test in boiling water I put the cap back on without the spring and plunger. Now the oil does not go to the front oil cooler at all. My thinking was like the with old V-8 water pumpers where you could pull the thermostat out and let the fluid run continuously. Is it necessary to have the spring and plunger in there at all times.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 04-16-2006, 05:04 AM
