Still Doin Time
asphaltgambler's Avatar
Oil Tank Removal Question - 85 Targa
Removing my oil tank this weekend and flushing the lines. What (specific) tools are required to remove the oil tank? Since the car is at home I need to plan what tools to take with me from work.
Thanks!
Old 05-19-2006, 06:53 AM
buster73's Avatar
Actually not many tools needed. A flat blade screw driver and a 36 mm wrench for the oil lines and hoses and a (13 mm) wrench or socket for the oil tank mounting bolts. You might have to take out the outer fender/rear bumber brackets (not sure with your 85). Of course it is always good to have as many tools with you as possible. There is always something coming up you did not expect. Good luck and :
Good idea to drain the oil before
Regards,
Guenter
73.5 911T, mod
Old 05-19-2006, 06:12 PM
I'm with Bill
Rick V's Avatar
liquid wrench
Old 05-19-2006, 06:14 PM
