Sound Deadening Recommendations?
My car has had all the material removed from under the carpets before I bought it and nothing is in the doors either. The doors sound like a tin can when I close them and I'm sure the sound deadening would help greatly. I'd like to install a product with the best features and after a search on the internet I'm more confused than ever. I'm hoping to do the floor and doors for about $200 or so.
I was wondering if any of you have used any of the listed products or could recommend another. Some even offer a paint-on sound deadener. Here are some I found: B-Quiet eDead Dynamat Fatmat eXtreme QuietCar Thanks, Dave
Dave Taylor 1974 911 Coupe 2.7 Guards Red/Black Trim, Tbitz EFI, MSD 1974 Super Beetle Sun Bug 1959 356A (sold) 1954 Hudson Hornet Project For Sale 18 Years In Storage 1974 911 My Car in the Pelican Gallery |
do a search here on 'dynamat'..i think you'll find that many have chosen this product..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Band.
IIRC, there's not a whole lot of "stuff" under the carpet in a stock configuration anyway.
When I redid the inside of my car, I covered the whole inside (excluding the part right under your feet) with "b-quiet" and I am very satisfied. It is pretty much identical to Dynamat and much much much cheaper, and delivered right to your door. No PITA ordeal at the stereo shop. I also covered most of inside of the doors, too. Your car may have some felt-ish cottony material glued to the main skin of the door. If not, you can just put a few modestly sized squares on the inside of the skin. No need really to cover the whole thing (the main skin). Stuff like b-quiet and dynamat are meant to reduce vibration, not necessarily reduce overall noise. But everything helps. I would recommend you don't spray any kind of sound deadener stuff, unless you're VERY sure you want to. It's kind of hard to undo.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
On the doors: The saturated felt stuff on the skin helps to deaden the drum head effect of the skin, bit if the doors are sounding "tinny," perhaps the door panels are to blame. IF the PO removed the floor material, what did he do to the doors? Light weight RS panels can't stop the noise of a tinny door like the bulk of all the pockets, arm rests, etc. Of course, the main area of concern is the rear shelf, bulkhead and the seat bowls. A substantial layer of heat reflecting and sound deadening material will help big time here. It doesn't have to be heavy to work, but that helps on the sound side more than on the heat side of the problem. All my .02, as usual. |
Thanks guys,
I'll probably go for the Dynamat although I'm open to using something less expensive if I could get the same effect. Dave
Make Bruins Great Again
"Sound Deadening Recommendations?"
Tell the wife to stay home if she didn't like the way you took that last corner. Makes the car much more peaceful and you can hear the motor much clearer.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Dynamat, undercoat spray. They are both heavy but dyna,at is expensive.
Fat butt 911, 1987 |
funny thing..i'm always seeking ways to better hear that 'ol flat six..
![]() ryan
well, I like to hear the exhaust sound too but not the sound through the body and entering the cabin. It's diff, just don't know how to discribe the diff. It's more of the vibration, resonated sound. Well, I hope someone know what I am talking about to translate it
