Yet more alternator problems?
I just replaced my alternator and today I was setting the timing and noticed that above 3500 rpm's the alternator light comes on. What could be causing this?
Mike |
Is the belt slipping?
I checked the belt and its tight. I might make it tighter to see if it makes a difference. I cant hear it slipping but then again my gutted muffler is kinda loud!
Mike --
I'd suggests you check your grounds. Most of my most mysterious and irritating electrical issues have been a result of a bad ground. T. |
odd..usually if the light is going to come on, it's going to be at low rpms and if the brushes are wearing out, it takes a bunch of rpms to extinguish it. is the alternator internally or externally regulated? have you checked system voltage at various rpms?
ryan |
the system is externally regulated. I haven't checked the voltage at dif. rpm's will do that later today. What are the symptoms of a bad external regulator?
ryan |
Mike,
Is the warning lamp full brightness, or perhaps only a half-bright glow? If the system Voltage is 13.2 - 14.5 Volts from idle to full rervs and the glow is only half-bright ... it isn't a real problem, just a phantom. Older electrical systems can develop Voltage drops at all of the connections due to corrosion and that causes the lamp to glow dimly. You can ignore it or clean every connection ... from all ground straps at alternator and regulator panel ... all connections at the alternator, regulator, 14-pin connector, and at the warning lamp Faston and bulb holder body! |
hi warren :) is it just my imagination..doesn't seem like i've seen you posting as much in recent weeks? good to see you at any rate.
ryan |
Thanks for the advice warren. It isn't glowing very bright. It just worries me to see it on!
I checked it again tonight in hte dark just because I wasn't 100% sure. The light does seem to come on light around 3300ish and and very bright at 3500+. Anyone know whats going on?
Mike |
mike...did you ever check your system voltage with a voltmeter with the car running?
ryan |
not yet, I need to go pick one up. Im only 18 and just started building my tool collection! Ill check it today.
Mike |
okay..i understand that. you'll find they come in analog (just a moving needle) and digital form. try to get the digital model if you can..doesn't have to be the most expensive model either, but digital is more accurate and you'll find a use for it all the years you own cars. with the car running, if the cig lighter works that's a place you could hook up the leads or at the battery terminals themselves. with the car off, it should read around 12 volts at the vattery of course, but while running, expect it to read between 13.5 and 14.5 volts..that's where the voltage regulator 'regulates' your system voltage. if you can check it at various rpm's and at times goes much beyond this, i'd suspect regulator problems. some times people see 15, 16 volts..means a faulty regulator and can destroy a battery through overcharging it in the process. good luck!
ryan |
Well I tested the battery today with VERY interesting results. I tried to start it up and the battery was dead. I charged the battery and started her up. She read 11.97 but slowly dropped in voltage about a hundreth of a volt every couple seconds and would then stop about every tenth of a volt. I decided to take her around the block and she died about halfway down my block. Obviously the new alternator I installed isn't charging the battery. The weird thing is the alternator light isn't on anymore. I am going to tear it down and triple check the alternator connections. Could it possibly be the external regulator? Im sooo sick of dealing with stupid electrical issues! I just want to drive!!!!
Still frustrated, Mike |
mike,
many on the board will change batteries every 2-3 years, just because it's 'cheap insurance'. if your battery is very weak, your alternator is not designed very well at to re-charge it..that's understating it. my advice (i'm assuming an old, weak battery with dead or dying cells) is to buy a new battery and see what happens. with the new battery, check system voltage while the car is running..that way you'll see what the voltage regulator is doing. it should regulate alternator output to 13.5 - 14.5 volts. if it's higher than that, say 16, 17 volts, i'd be suspicious of your regulator..and that could be the reason that the current battery is dead - it's been overcharged and in essence, 'burned up'. on the other hand, of the voltage is low, say 12 volts, i'd suspect your alternator..that would suggest that battery voltage alone is trying to power your system. ryan |
The more I think about it the more im suspecting the alternator. probably because I just replaced it. If there was a problem with the alternator wouldn't the light be on though?
Mike,
If you have to pull the alternator again check the grounding strap. It won't work without it attached. Maybe you can take the alternator in to a shop to test it, too. Let us know when you solve the problem. Dave |
where did you get the alternator? do you recall the brand, number of amps? did you do the installation? could be that the ground strap isn't tight..or maybe not connected? other wires not on the right posts?
ryan |
Marchal 60 70 amp. I picked it up from a pelican. Had a rebuilt sticker onit from 05. I installed it... which im concluding was/is the problem. Ill check it out and keep you guys posted. thanks for the help bigchillcar
Mike |
very welcome mike..good luck! i know the process of removing and re-installing the alternator can be a pain..always seems my hands are a hair too big for the job. dave is in concurrence with me, too about the ground strap..
ryan |
Yea its a TOTAL PAIN IN THE A$$!!! I always wonder if the german engineers ever meant for these cars to come back apart!
:D
I truly believe that much of the designing was done during Oktoberfest!! http://www.pelicanparts.com/support/smileys/wat6.gif
Well I checked and double checked all of the connections on the alternator and they are all hooked up correctly. I dont really know what to start checking from here. Any suggestions?
Mike |
You may want to have an electrical shop load test it. On one occasion I ended up removing mine three times. By the last time I was very efficient at taking it out. I removed it the first time because the light was on. Installed the rebuilt unit. It ran about a day then the light came on again. Removed it and found one of the brushes was sticking in the holster and not touching the commutator. Fixed that and put it back in. Alternator ran one week. Pulled it again to find the spring that holds down the brush had snapped allowing the brush to back out. Fixed that and the alternator lasted about 10 years.
Another time I found one of the solder joints on one diode had cracked from age, heat, and vibration. The crack was not visible but was enough that the alternator light would come on. It only showed up when the diode was wiggled under load. I had all the joints sucked free of the old stuff and new solder put in. In summary, I would: 1) pull the alternator again 2) check that the commutator brushes move up and down freely 3) check the brush hold down springs 4) Have it tested under load to see if the charging voltage holds while the diodes are wiggled Of course the suggestions by the others are possibilities as well but these are areas where I've personally experienced issues. So you don't feel it's a total rework effort, polish your fan while it's out. Good luck |
Thanks for the suggestions autobonrun, Looks like its coming out for the 3rd and hopefully final time!
Mike |
has a check of systme voltage still not been donw with engine running? still could be something as simple as the ext vr..
ryan |
Mike,
I've been following this thread with interest (as you might imagine). One test you can try if you still have everything hooked up is to look at the field voltage from the regulator with the engine running. I'm not sure what color the wire is on your regulator but if there is a lable it should be DF (the F stands for field). This wire is how the regulator controls the output of the alternator. When the voltage output of the alternator is low as is the case on your car, the regulator will raise the voltage on the field to try to get the alternator to increase it's voltage. The field voltage should be high if the regulator is working. By high I'd guess it should be around the same as your battery voltage (about 12 volts). If this wire is low (less than 5 volts) then I think your regulator is bad. I'm kind of guessing at these numbers but hopefully the voltage will be about zero or 12 and that will resolve the issue. You may be able to have the alternator tested at Autozone (probably need to put a pulley on it somehow. If the alternator really is the problem I'll buy it back from you. -Andy |
think an alternator shop might be able to bench test your vr..i'd do that if they can before pulling the mother****er again.. ;)
ryan |
I've also been following this. I thought my alternater was bad after some dim lights after a little run, and almost stalling out at a stop sign 3 times. But let me know what you think. I had my battery tested in the car at my shop. It read about 12 at idle. At 2000 RPM, it showed high 11's and said "not up to specs". Now, my voltage meter has not worked for about 6 months. I hooked it up this week and it shows about 14 at 65MPH. Good, I think. Now the question??? Would having a volt meter NOT hooked up cause a drain? Would having it disconnected cause a "break" in the circut showing the battery, or having the battery go down. Thanks for any help.
I was starting under the assumption that everything else tested good. A bad VR is definitely a possibility. It costs extra but I've always replaced my VR when I've replaced my alternator. Just a personal choice and it may be unnecessary, but I've been more comfortable replacing the entire charging circuit. You can never tell if a bad VR caused an alternator problem or vice versa. |
and the battery? take it to a napa and let them put a load on it. it may have dead cells as i indicated earlier. these alternators DO NOT perform well when they're constantly forced to shore up a dying battery..
ryan |
I really appreciate all of the help guys! I didnt even bother working on it today because im just so ****** frustrated with it right now. Tom i will take the battery in to get tested and the VR bench tested. Hopefully ill get this resolved soon.
Eagledriver- Even if the alt. is the problem I am planning on keeping it and getting it rebuilt or whatever needs to be fixed, fixed. I appreciate the offer though. Mike |
| All times are GMT -8. The time now is 11:15 PM. |
