CRNT918's Avatar
Question '83 into '78 SC transplant question
I am temporarily transplanting an '83 SC engine into a '78 SC.
I would like to this as a plug and play, not changing anything on the '78. What do I need to remove from the original '78 engine
to make the '83 work. I DO NOT want to use the lambda sensor and brain. Any suggestions?
Thanx,
Pete
PCA-Chicago Region-DE Tech Coordinator-Retired
PCA-Chicago Region GingerMan DE Co-Chair-Retired
1987 Cab-under construction-Sold pending pickup
1986 911- Race/DE car-Sold
Old 04-16-2006, 08:16 PM
Somewhere in the Midwest
MotoSook's Avatar
Pete,
Why not put your 78 induction onto the 83 engine. Just use the 83 long block...then it's plug and play.
Old 04-16-2006, 08:21 PM
CRNT918's Avatar
Isn't there an alternator/voltage regulator issue?
Old 04-17-2006, 03:18 AM
MotoSook's Avatar
You can swap the old alternator (with external regulator) with the later (internal regulator) alternator. Or just convert the wiring (one or two wires...that's it) to the later onboard voltage regulator scheme. Easy to do and just about everyone has done it to their car by now. I've got a tech article on my web page somewhere to help with the conversion.
Old 04-17-2006, 02:20 PM
Will the larger 78 runners work with the later heads with the smaller ports?
Old 04-17-2006, 06:57 PM
