Is this fan noise OK?
Now that my CIS is fixed I can actually hear my engine.
I'm hearing a "whackatta - whackatta" type noise that sounds like its coming from the fan area. It does not sound like valve noise On an 3.0 ltr, is that a normal sound?
Garage is empty Gone:96 TVR Chimaera, 05' Mazdaspeed MX5/89' Caterham Super Seven/84' Carrera/81' 911 SC targa/74' MGB |
Friend of Warren
Sounds, literally, like the fan is hitting the housing. Either loose alternator bolts, bad alternator bearings or cracked fan housing.
Kurt V No more Porsches, but a revolving number of motorcycles. |
That area is very near the chains and tensioners. Get a mechanic's stethoscope and isolate it. You could also briefly, very briefly, remove the fan belt to determine whether it's the fan or not. A cold engine without a fan for 15-30 seconds shouldn't be a problem. If the "whackatta - whackatta" goes away then you know it's in the fan assembly. If it doesn't, then you need to look elsewhere. Noise travels!
Is the fan spinning smoothly?
Does it look like it is out of balance? My car was making a noise from the fan and the pulley nut hole (sorry bad description) was rounded off and was wobbling. Hope that's helpful...?
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon (new addition 1998 Mazda Roadster) EX - 1993 Porsche 911 Carrera 2 EX - 1979 Porsche 911SC TARGA EX - 1976 BMW 2002 |
Driving member
Check the fan and housing for scratchs/gouges. I had some sort of debris that got caught between the fan and housing and dug in causing a big burr that would catch the fan blade slightly.
I took sandpaper from coarse to fine to sand out the burr and it has been good for 3 years or so.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
turns out it was valves
Weird, I had the valves adjusted less than 3,000 miles ago by a shop I trust....hmmm
My local (now very trusted) mechanic Frank used a stethoscope thingy and diagnosed it as rocker #6. $40 CDN later, he adjusted it and I'm back on the road. He suggested that I get them all adjusted as #4 was off too. What makes a valve set to go out of sync so quickly? Do the adjuster mechanisms wear out?
Paper Member
If you think it's the fan or alternator you could just take off the belt and spin the fan by hand without running the engine. Should be nice and quiet.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Re: turns out it was valves
Sounds like the beginning of a good relationship. Stick with that mechanic! |
Ya, Frank charges $55 CDN an hour...partly because he is not a licensed mechanic by trade. However he has been working on Porsche 911s for ages and has been running race cars. I trust his judgement. He has not led me wrong yet. Also he is a 5 minute walk from home.
I think I might adopt him Man....I sure wish I had someone local who would even think of looking at my car for $40, much less repair it for that price!
A sudden change in the usage of the car? If the car had sat for awhile, you might (with regular use) have burned a lump of carbon off a valve or seat that would open up the clearance... ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
