David in VA's Avatar
New tow hook options?
I've seen several discussions on tow hook and jack pad options for those of us with stock bumpers, none of which seems ideal. Does anyone have any experience with the new ones advertised here?
http://www.*****************.com/Tow_Hook_Jack_Pad_p/rm-1310.htm
http://www.*****************.com/product_p/rm-1325.htm
They both say no body modifications needed, sounds interesting.
'87 911 Coupe
'95 911 Coupe
'04 911 GT3
'98 Jeep Wrangler
Old 05-30-2007, 09:31 AM
81 911 SC's Avatar
I have the renline fronts but I have yet to get them on my car. They look like the bolt on with no modification though
- Tyler
1988 911 Carrera Grand Prix White/Black
2015 Cayenne Diesel Black/ Luxor Beige/Black
Old 05-30-2007, 09:34 AM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
That Jack pad and tow hook (combo) did not fit my 3.2L. The oil sump return hardline is in the way.
I bought mine from our host for $89 or so. Looks exactly like the one from your link. I may modify it so that it will work (wled on some 1/4" sheet steel to extent the forward and aft mounts), but it'll just be about an inch lower so that it will clear the oil line.
The tow hooks that Rennline sells for the front torsion bar cover plates are a bolt-on. They even come with new hardware (bolts) for each mount. I'll be ordering those in the near future.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 05-30-2007, 09:40 AM
Thanks for the feedback Matt. I thought it might be a different product than the Weltmeister but I guess it's the same one for the rear. The front doesn't appear on the rennline website, is that the one you're talking about? Seems like a bargain for $21.
'87 911 Coupe
'95 911 Coupe
'04 911 GT3
'98 Jeep Wrangler
Old 05-30-2007, 09:49 AM
