need help: steering rack lock ring?
hey all,
I just finished replacing the tie rods with the turbo tie rods and I found that on the driver's side there were some parts which _should_ have been in the steering box which were not. Three parts to be exact....a lock ring (?) with maybe 12 teeth around the outside, a rubber ring (1/8 inch wide), and a plastic ring maybe 1/4 inch wide. The lock ring was cracked which I'm assuming allowed the pieces to come out. Without the pieces the in the box, the rack becomes loose thus resulting in a little play in the steering. Does anyone have any info on this? perhaps a diagram of the rack? whats the part number here on pelican parts?
btw...the turbo tie rods is probably the best upgrade i've done so far! i would suggest it to everyone with the carrera rods.
thanks for your help,
Old 04-18-2006, 09:32 AM
bump...any diagrams or part numbers?
Old 04-18-2006, 10:34 AM
jwetering's Avatar
No diagrams but there are quite a few good threads on steering rack rebuilds on this site - dig around a bit. I just rebuilt my rack, and the parts you describe keep the rack aligned with the pinion ie centred in the steering assembly. . Important to say the least. I personally wouldn't do a whole lot of driving until you've sorted that out.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 04-18-2006, 11:51 AM
i couldn't find any detailed posts on steering rack rebuild...anyone have any more input???
Old 04-18-2006, 02:47 PM
bump
Old 04-18-2006, 04:29 PM
is there a rebuild kit for these racks?
Old 04-19-2006, 09:28 AM
rebuild kit for steering racks? anyone?
Old 04-19-2006, 11:17 AM
bump
Old 04-19-2006, 01:01 PM
heiliges blechle!
I found this thread:
SC Steering Rack DIY Bearing Replace
Now I have another project to add to the rapidly growing list.
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 04-19-2006, 01:45 PM
David, I think I can help you out. I believe you are talking about a Seeger ring, It is a locking type ring designed to be pushed in and lock into place. In your case it's tabs lock the guide sleeve for the steering rack into the housing. I looked all over the place to no avail. When I was putting in a quick fix sleeve for a loose steering wheel i noticed there was what appeared to be and identical ring on the steering column. It is pelican part #999-041-102-01-oem. For $1. it may be what you are seeking. Since it is oem, you may can get a peek at it at a dealership before ordering it from our host, of course . Hope this helps.
Ray
'88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia
Old 04-19-2006, 02:16 PM
