safe's Avatar
Rear swaybar upgrade.
If I would like to upgrade my stock swaybar in the rear (16 mm).
Since it has the ball-type connection to the trailing arms, what are my options?
Do I need to get the type that connects to the springplate?
Magnus
Old 04-18-2006, 10:50 AM
safe's Avatar
bump
Magnus
Old 04-19-2006, 10:42 AM
juicersr's Avatar
As far as i know, you should be able to upgrade all the way to (nonadjustable) Carrera bars in the rear (21mm). I just did and noticed a significant improvement in cornering when combined with 22mm Carrera fronts. The adjustables take it further if you are hardcore DE, but are $$$...
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 04-19-2006, 12:00 PM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
I run a Carrera rear sway in my '74 with the ball-type arms and I haven't had any problems. You'll need to fab some mounts for the ball-type link to attach to the Carrera sway though, pretty simple to do actually.
If you go any larger than the Carrear Im pretty sure you're going to need to either upgrade the arms or use a sway that attaches to the spring plates.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 04-19-2006, 12:51 PM
78-911SC's Avatar
Denny Crane
PJ
78 911sc Targa
70 911T
Old 04-19-2006, 01:19 PM
