A/C leak, where to have fixed?
I have a small leak in one of my a/c lines, this this something my regular mechanic doesn't work on. My question is, should I have this fixed at a Porsche specialist or would I be okay with a regular shop that works on A/c systems? Bearing in mind I haven't found a shop that works on a/c, but I presume there must be many in this area. Any recommendations?
Many thanks Matt |
I have all my a/c issues fixed into a local shop with no problem. Jur need to find an intelligent guy.
So, the question then should be, does anyone know of a good a/c shop in the bay area?
Matt |
The biggest scam in the world is to unscrew the schrader valve
and you have a life time recharge customer. Just buy a valve stem tool and see if you can tighten the core first. Keith Epperly 87 slant nose turbo look carrera cabriolet |
also you can check the fittings if they looks greasy or wet with oil tighten it because they are leaking.
| All times are GMT -8. The time now is 05:11 AM. |
