Is there a benefit to "backdating" to a non-helper spring setup? Granted, it's alot easier to work with, but is there an advantage? I have a mag-case transmission without the helper spring and I'm just curious.
Old 09-07-2006, 10:50 AM
Okay, I just did a quick-fix using my four favorite "tools"... Baling wire, washers, zip ties, and JB Weld!
I road-tested after just two wraps of baling wire and washers and it was holding up fine. Two more wraps of baling wire, JB Weld, and a zip-tie for insurance, and I'm about as confident as I can be that it'll all be good. I've taken pics - will post them up when I get a chance.
But still a little confused on the Wevo part vs. the ~$15 Porsche part referenced above. If I'm reading correctly, I *think* what I need is the $15 Porsche part and the Wevo part is for the earlier (pre '77) 915's. Is that correct?
Brad
Old 09-07-2006, 03:40 PM
Here's what a quick&dirty (yet highly functional), fix looks like. Held up just fine over 800 miles of driving, though I must admit, I did clutch-less shift whenever possible. If anyone could confirm that what I need is the $15 part (for a proper fix), that would be appreciated.
Brad
Old 09-14-2006, 04:43 PM
gduke's Avatar
I can see a real benifit w/ the Wevo. It looks much stronger than the factory part. The factory pary looks brittle.
Gary
1985 911 Carerra Cab 3.6l
1998 Dodge Ram
2004 Toyota Tundra Quad Cab
Old 10-29-2006, 05:35 PM
the factory part will break just from sitting the trans on the ground.
206 637 4071
Old 10-30-2006, 08:34 AM
But does the Wevo part work with both the early and late 915's? I was lead to believe it is designed to work only with the early 915.
Regardless, I still believe my solution (pictured above) is the most elegant and functional.
Yes, I'm kidding....
Brad
Old 10-30-2006, 08:46 AM
HarryD's Avatar
Originally posted by wevoid
Just so there is no confusion, the WEVO part that Tyson showed does not need the billet side cover to function.
Here it is mounted with a normal side cover.
This part is $68, so you are not going to get far with materials and effort before this is a fair and easy deal.
Pelican can supply you, just tell them you want to buy a "WEVO XT-206 Clutch cable bracket" and they will be able to help you out.
Regards
Hayden
Hayden,
Today, I had Kurt at Marque Motors (Portland) install your part in my car. He reported that the fit was great, went it with absolutely no problem and much faster to install than he anticipated. He purchased the kit with the longer studs.
Everybody's parts should fit so well .
My clutch operation feels 100% better and I wish I knew of this fix sooner.
Thanks for the suppport for our older cars.
Here are some after shots (my before ones are above):
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 03-28-2007, 08:36 PM
Good to see this thread come back up, as I put my '86 away last Fall with my "red-neck JB Weld & bailing wire" fix, but now that Spring is here, I need to do a proper fix. Maybe I've just forgotten, but I'm not clear on whether the Wevo part is only for the earlier cars? Should I just buy the ~$15 factory fix part?
Brad
Old 03-29-2007, 09:23 AM
HarryD's Avatar
I think the Wevo part is for older cars without the omega spring.
Harry
2003 BMW Z4 3.0i
2009 MB C300
Old 03-29-2007, 03:59 PM
kinein's Avatar
Send a message via Yahoo to kinein
mine broke tonite even though this is 5yrs ago
1966 912 with 2.2 911 motor
1986 wide body 911
1995 993 Polar Silver
Old 05-30-2012, 10:24 PM
Good God, was it really 8 years ago that I did this? I guess you don't want to know that my "temporary fix" is still holding up just fine. Damn you JB Weld!
Brad
Old 06-05-2012, 05:17 PM
tobluforu's Avatar
Mine cracked on my 75, just enough so the hole on one side cracked almost all the way off. I drilled through the remainder of the mount and bolted a piece of steel to the broken side, I then back fill it with gator epoxy.
Old 06-05-2012, 06:58 PM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
My 1974 911 coupe has a European 3.2 liter engine and transmission installed and I think my clutch cable may have a problem. Interesting thread.
Thanks for sharing.
Henry
Old 09-30-2019, 12:46 PM
914-6Werkshop
Mine came broken but since I was taking the trans apart anyway I sent the case part to Ben/MB911. He welded in mag filler and built it up so it looked similar to original. I still have to drill a hole in the piece but it's good to go. I didn't know about the aftermarket brackets or I would have done one just because it's cheaper than shipping and welding but if you want it to look original, call Ben.
Old 09-30-2019, 01:34 PM
