Cruise Control connections
On a '82 SC 3.0 ltr where does the vacuum line from the cruise control servo connect to the throttle body? Does it just 'T' off an existing vacuum line?
Old 04-19-2006, 03:39 PM
I would love to know myself too! I can't tell from the diagrams transferring to the real world where this plugs in.
Vacuum off the CC unit.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 04-19-2006, 04:34 PM
Alii&Maui
Jesset100's Avatar
That's just a vent hose. It's hooked up to nothing.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 04-19-2006, 07:04 PM
avt007's Avatar
That vent goes nowhere, however, on my 86, just forward of that hose is much smaller nipple for a small vacuum hose that goes to a T fitting in the vacuum line to the brake booster.
Rob
76 widebody project
86 Carrera Coupe
01 BMW X5
98 Jaguar XJ8
Old 04-21-2006, 03:05 PM
Thanks on the vent hose heads up.
I was hoping for the simple solution to the CC not working.
Jung
'68 912 Coupe
'82 SC sunroof
Old 04-21-2006, 05:09 PM
avt007's Avatar
Cheer up, mine doesn't work either!
Rob
76 widebody project
86 Carrera Coupe
01 BMW X5
98 Jaguar XJ8
Old 04-21-2006, 06:06 PM
avt007's Avatar
Hope this helps- I've also adjusted the cruise throttle cable, it wasn't very tight, I'll let you know if that helps. In this pic, you can see the brass fitting for the hose;
Rob
76 widebody project
86 Carrera Coupe
01 BMW X5
98 Jaguar XJ8
Old 04-22-2006, 09:16 AM
