Spacers to widen ATE calipers.
Does anyone sell or make spacers to widen ATE calipers? I want ot take a set of front 914 calipers and use them on the rear of a 911. I want to take advantage of the larger pistons in the 914 caliper.
No such kit or pieces available ...
IIRC, the 914 calipers have 42 mm pistons ... the same as '84 thru '89 rear calipers. It would be cheaper to just get a set of used Carrera 3.2 calipers and rebuild them ... since the spacers would have to be custom-made to order!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
As Warren said Carrera rears have 42mm pistons and 3" bolt spacing so wil bolt on, you do need Carrera rear rotors as well.
as an aside you must have some mighty large front caliper pistons and an equally large m/c
