				Front wheel bearings
			Hey guy i have a77 911s  are the front wheel bearings hard to replace myself?
			Nope. If you have one of the many service books available they are easy to do. 101 Projects for your Porsche 911 is a good choice as well as the Haynes or Bentley manual.
			Another optionis to searchpast threads here on Pelican. Tons of useful tips and information for you.
	1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne  |
			Don't forget to purchase a set of wheel seals also.
	'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring)  |
			 coolcavaracing.com
			Stupid question time
			  What are the wheel seals??
	Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
 Mike
	Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes  |
			 coolcavaracing.com
			Thank you for the education Mike
			 Regenerated User
			How do you know when it's time to rebuild the bearing?  If I have the car on a lift and I push/pull (perpendicular) the wheel I don't feel any movement but I can hear a faint clunk.  Is this normal?
	My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002  |
			A faint "clunk" is probably normal.  It seems that 911 front wheel bearings - even when adjusted correctly - seem to exhibit a little bit of movement when you push/pull on the rotor.  "Little bit" is very relative, of course.  Sometimes it's hard to determine exactly where the "clunk" is coming from.  Sometimes it's not bearings - I've seen a little bit of play where the strut insert (shock) threads into the housing.
			The true test of "when to replace" is to remove them, clean them and inspect them. As long as the bearings look good, there is no reason to replace them. Believe it or not, my car (over 30 years old now) still has the original front wheel bearings. I have repacked them numerous times, but they are original and they look OK. Don't fix it if it ain't broke... Mike
			When one of mine went bad I could hear a whine when turning corners.  When I replaced them there wasn't any visible damage, but the noise went away. If you hear them they are worn out, I don't know of any other way to check.
	Jesse 76 911S  |
			What i fyou hear a slight whine when driving in a streight line?
	85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board  |
			 Automotive Monomaniac
	2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)  |
 thanks!
	X/A  |
			Front bearings are easy to replace!   Do it.  Do it.
	Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr"  |
			i have porsche 101 projects and its not in it, and i can not find it in this form on how to do it, any help thanks?
			To replace the bearings:
					1. Remove dust cap, kind of a pain, light taps with a hammer 2. Remove cotter pin and remove nut and washer 3. Remove outer bearing. 4. Remove rotor and hub 5. Remove dust seal and remove inner bearing 6. Clean hub assembly. 6a. Remove rotor (optional) 7. Drive out the bearing races 8. Clean hub assembly again. 9. Stick new bearing races into the freezer 10. Place hub into oven (if wife not looking) or Gas BBQ grill (low temp) 11. Remove hub once it is warm. 12. Drive the cold races into the warm hub (Use special bearing race driving tool) 13. Pack bearings 14. Install inner bearing w/lots of grease (I like Mobile One Red synthetic grease) 15. Install dust seal 16. Install rotor 17. Put hub assembly onto car 18. Install packed outer bearing use lots of grease 19. Install washer and nut 20. Washer should be still be able to move using a screw driver 21. Install new cotter pin 22. Install dust cover 23. Reject bearings after ~50 miles This is just a quick list. Others may comment. There is a tech article on brake ducts on the PP site that covers a bunch of this stuff. FWIW, do not use 'made in China' bearings IMHO
