aleng888's Avatar
help about a oil line
I have a 1974 911 with a 2.7 motor in it right now. but next weekend i am going to take the 2.7 motor out and put in a 1985 3.2 L motor. The guy that come over to do the swap say i need a new oil line from the Engine to Thermostat. I found two differnt line in pelican . the two partname and number are
1. Oil Line from Engine Hard Line to Thermostat (Only for cars w/front oil cooler), 911 (1974), Note: Used when backdating to 74 type or SSI heat exchangers. part#911-107-729-10-M20
2. Oil Line from Thermostat to Engine Oil Line (Only for cars w/front oil cooler), 911 (1975-83), 911 Turbo (1976-77)
part# 911-107-743-10-M20
Please help , want to made sure i get the right part.
Alan
76 911 w/2.7
74 911 w/3.2
Old 04-20-2006, 05:27 PM
crashr's Avatar
Alan, I believe the guy that came over to do the swap was telling you that you will need to add an externel oil cooler at the front of the car, to cool the 3.2 engine. I recently did the 2.7 to 3.2 conversion on my 75 and I had to add a front oil cooler, as well as lines that run to the front of the car. The thermostat that you are reffering to is also external, and you will need to purchase as well.
1975 Widebody 911 3.2 Euro
Old 04-20-2006, 05:37 PM
Neil Peart Fan
Pele911's Avatar
You dont HAVE to add the carrera oil cooler although it is a great upgrade. The factory had the trombone "cooler" on the 930's so it is not a requirement for the swap.
Old 04-20-2006, 05:44 PM
aleng888's Avatar
I already have oil cooler in the car. he say i need a new oil line is becasue the one in the car will not fit the 3.2 L Engine.
alan
76 911 w/2.7
74 911 w/3.2
Old 04-20-2006, 06:46 PM
DW SD's Avatar
What oil line you select depends upon the exhaust and type of cooler that you will be running.
First, which exhaust are you going to run? If the '85 is stock, then you'll need the oil lines (2, I believe) for the '85 3.2. One line wraps from the sump around the back of the crankcase and then second is a soft line attaching that to the thermostat, assuming you are using an external factory-style thermostat, for your oil cooling.
If you are running back dated exhuast SSI or factory early Heat exchangers for the swap, then you'll use this part: 911-107-729-10-M20
Also, there are several oil cooler types. One is attached to the engine itself. A second is external, with hard lines running up the side of the body. I assume you have the external cooler with factory externally mounted thermostat and air to oil heat exhcanger (cooler)?
The stock 3.2 installations actually ran both types of cooler (engine + external). This is recommended for stock longevity and performance.
Please provide some more informatoin and we can offer a better recommendation.
Doug
1971 RSR - interpretation
Old 04-20-2006, 06:59 PM
