-   -   Poor idle (http://forums.pelicanparts.com/porsche-911-technical-forum/278418-poor-idle.html)
PatBuckley 04-20-2006 08:25 PM
Poor idle
My 86 911 has a strange idle -
When it is warm the idle has a rhythmic lope - if I put it in gear and slightly engage the clutch the idle will stabilize and stay that way until the engine is revved again - then it will go back to the lope.
I have replaced the ISC valve with no change.
Do you suppose I have a throttle plate that needs to be closed down a hair (is this even possible) or perhaps an air leak?
Thanks!
Great forum.
