grease on ivory headliner
hello all,
posted this topic in the cleaning category, but it's not very active. I got some grease on my ivory colored headliner-swapped out the old cables. What should i use to clean it? Any suggestions.
best, paul.
84 R5 T2
04 Suby Outback
"it's a mystery, wrapped in a riddle, inside an enigma" Winston Churchill.
Old 04-21-2006, 11:49 AM
Dealerships have used "Brake Kleen" for many years to clean grease from interiors. The spray dissolves grease almost instantly. Spray and blot. Repeat if necessary. You want the spray to do the work as much as possible (not the cleaning cloth). Do your best not to rub the grease into the fabric. I've used many times with success.
As always try a bit in an inconspicuous area to insure compatibility. Good luck.
Warren & Ron, may you rest in Peace.
Old 04-21-2006, 11:53 AM
DW SD's Avatar
Try hot water with some orange degreaser. Blot don't rub, like Rick said. I'd be concerned that brake cleaner may remove the color, but I know his advice is excellent!
Doug
1971 RSR - interpretation
Old 04-21-2006, 11:58 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
or try Simple Green...
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 04-21-2006, 12:07 PM
RLJ RLJ is offline
Senior Registered User
After the brake kleen put some 303 on it.
Randy Jones,
1971 91 "Iris"
Old 04-21-2006, 12:22 PM
scottb's Avatar
Folex carpet and upholstery cleaner is great for this exact problem. YMMV
1984 Targa
Old 04-21-2006, 12:25 PM
Doug
Thanks Doug.
Regarding the color; I've never had the dye from carpet or fabric come off when using. But it's always worth using on a test area first. Also, I've use it on jeans or other clothes and it works great. Someone once told me it's what many dry cleaners use....who knows.
Old 04-21-2006, 12:40 PM
defcon65's Avatar
Carbona, if you can find it. Works great but contains carbon-tetrachloride, so open the windows and avoid inhalation.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 04-21-2006, 12:59 PM
jeff1hughes's Avatar
I've used BlueMagic leather and vinyl cleaner for grease and even shoe polish on carpeting. You can find it at NAPA, part # is 800. That or I'd use citrus hand cleaner, works like magic, gentle on everything!
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 04-21-2006, 04:34 PM
