930 turbo transplant
I want to put an 1989 porsche 911 turbo motor into my 1973 911 is this a hard job and what bo i need? Will my stock tranny work and what about fuel pump and rear drive train?
Insert Tag Line HERE.....
It will work. What R&P ratio do you have? 73-75 was the changeover year, so you could have either depending on your build date. You might want to go to a 8:31 vs a 7:31 if you have that. What is in your car now? (engine/fuel setup?)
Marc Last edited by rattlsnak; 04-20-2006 at 08:08 PM.. |
if you can get the fuel pumps,lines from the turbo car you shouldnt need much else. you can run a single aftermarket pump but if the fuel pumps come with the motor you are purchasing get them. if the car has a 7:31 trans you might want to try and find a later 8:31. i did one in a 69 a while back but we used the turbo trans also.
Please don't do this to a '73.
Thank you. |
It will work but transmission will only hold up for mild driving. Mild driving will be hard to do with such setup.
Thank you for your time, |
You will need to change the length of the throttle rod at the throttle body; you will need extra oil cooling up front; you'll need a tail to clear the intercooler; you'll need to adapt the 14-pin harness on the 930 engine for the older car.
Then you'll have to get a second job to raise money for the EFI, G50 conversion, and rear flares.
993 |
Zombie
wow would thing even be drivable im envisioning a 180 when the turbo comes on!
it ain't fun unless it's dangerous. i would suggest selling your 73 trans and using a later aluminum 915. i had a 3.0 hotrod 930 in my 73 speedster conversion and it was awesome.
I'm in heaven, when I drive my nine eleven... |
