Is this grease ok instead of Optimoly HT?
Can't find Optimoly HT (000.043.004.00) anywhere.
Found this grease from Sta-Lube that has a drop point of 450 degrees. It does contain molybdenum. http://forums.pelicanparts.com/uploa...1145657517.jpg Would this work in it's place? I have no idea if I need something with a higher temperature limit. This is for tranny input shaft splines. |
Re: Is this grease ok instead of Optimoly HT?
Does it say EP - extreme pressure on that tube? I'd guess it does if it has Mb in it.
| All times are GMT -8. The time now is 04:03 PM. |
