Oh Haha's Avatar
Porsche Crest Cheap heat block off...will it work?
I found that my heater hoses had quite a few leaks in hidden areas so I removed the entire system. I don't really need it for the summer, anyway. I blocked off the opening to the fan. Will this work? It's basically the same principle as the Porsche part, just not as handsome. I left the HE connections open where the hoses connect. Is this ok?
Thanks for any tips you may have.
Pacific Blue
Wayne
Old 04-21-2006, 07:36 PM
Nitrometano's Avatar
yes he will work. I have a block off plate and my brothers 911 have a degreasser cap like yours and both do the work.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 04-21-2006, 08:46 PM
Oh Haha's Avatar
Thanks Nitro.
I'll put the system back on for the cooler months.
Pacific Blue
Wayne
Old 04-22-2006, 05:04 AM
Diss Member
Quicksilver's Avatar
The connection to the heat exchangers should be blocked off too. Heat rises and the heat that can come up out of the heat exchangers will melt things! Don't block it with something that isn't super heat resistant. (I have a piece of plastic slag as a reminder!)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 04-22-2006, 05:24 AM
I once measure the heated air temp at the defroster vents..something like 260 degrees! You might want to find a metal cap.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 04-22-2006, 07:11 AM
PorscheGuy79's Avatar
I have heard thats a very bad idea, there has to be air going through the heat exchangers, even if there are no tubes ducting it anywhere its just best to leave it open. I cant exactly remember why, but im sure there are threads explaining.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 04-22-2006, 07:14 AM
Formerly bb80sc
Vipergrün's Avatar
If you are not passing air through the heat exchangers, they will act as a large heat trap, saturating your lower valve covers with a lot of heat. Folks who typically run block-off plates, similar to what you are trying to accomplish, are running headers and do not need the heat. Does not seem like a good idea.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 04-22-2006, 07:25 AM
Thanks for the support on that topic Brad, for the life of me I couldnt remember the reasoning behind it.
Matthew
Old 04-22-2006, 07:41 AM
Oh Haha's Avatar
I went for a drive today and the only downside I noticed with the heat blockoff is more oil than normal seemed to be burning off my HE's. I know my engine leaks a bit but I never noticed it burning like that. Would it have been going into the heating system and now it just goes into the air?
Pacific Blue
Wayne
Old 04-22-2006, 11:04 AM
JBO JBO is offline
...so is the answer to leave the heat exchanger ends open when you pull off the hose? This has been the big confusion for me about backdating the heat, as reading the threads they talk of the block off plates on either side of the fan, keeping the stock exchangers but doesn't say what to do underneath when the hoses are pilled off the exchangers. This is still not clear to me.
Old 04-22-2006, 11:10 AM
If you are using the block off plates on either side of the fan housing then you should remove all the flexible tubing and leave the openings, front and rear, on the heat exchangers open.
EDIT: Just to be clear this also means you can unbolt and remove your heater blower motor.
Matthew
Old 04-22-2006, 11:20 AM
Oh Haha's Avatar
I'm good then. thanks
Pacific Blue
Wayne
Old 04-22-2006, 11:30 AM
araine901's Avatar
I have had some some plastic paint caps on mine for 7 years. No problems. Not the best looking but will work for sure.
'66 911 (sold to Magnus Walker)
'63 Myers Manx
'67 Cal Bug
'02 GTI 1.8T
Old 04-22-2006, 12:10 PM
I find more uses for PB blaster caps then I really should. haha.
Matthew
Old 04-22-2006, 12:16 PM
KlaasyT's Avatar
caps
Hi, I used the same method last summer on my 72t. Left all hoses off my exchangers and found I was consistenly running 100-110 + degrees celsius. Too Hot! I pulled the caps and hooked up the hoses and it never gets over 90. the hot air needs to be pushed out of the heat exchangers.
Clarence
72 911T Euro
81 931
71 911E Euro rusty on the bottom
72 911T project RS look
Old 04-22-2006, 01:42 PM
I'm running a high performance cat food can. They fit like they were intended for this mod.aluminum ta boot!
I notice no increase in temp. I think I may have gained about 15 HP out of this
Silver 1980SC Euro coupe
Old 04-22-2006, 01:55 PM
araine901's Avatar
I have to admit that I have headers with no heat hook ups and have blocked off the hose holes in the tin to keep the engine exhaust heat out.
'63 Myers Manx
'67 Cal Bug
'02 GTI 1.8T
Old 04-22-2006, 04:04 PM
