rotorhead's Avatar
How do I test my Fuel Distributer
Here's the story I have an 88 930 turbo that spent most of its life in the Middle East. It has always been low on power and I have determined that it is fuel related due to fouling of the fuel system.
I have:
Replaced the Fuel Tank
Replaced the injectors
Replaced the Fuel Filter
Replaced the Fuel Accumulator
Replaced the rear Fuel Pump
Rebuilt the top end of the engine
It now runs much better but with the amount of buildup in the tank/ acculator/injectors I figure that the FD is probably clagged.
I have put a Fuel pressure tester on it and measured and adjusted the pressures within limits. The pumps now flow within limits too (with the new rear pump).
The only component I can figure to be now restricting the fuel flow is the FD. So how do I test it?
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 04-23-2006, 12:53 AM
Steve,
There is a tester that may be available at some authorized Bosch repair shops. It is a strange device that measures the output of each of the ports in the fuel distributor, rather like a test of the fuel pump output. In other words, you measure how many cc's of fuel you get delivered in a set amount of time, for each cylinder. Obviously, the output for all cylinders needs to be the same.
If you can't find the tester, you can probably rig up something similar.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 04-23-2006, 03:23 AM
Designer King
Paulporsche's Avatar
There was a recent thread by someone who opened up and cleaned his FD.
You can also do a test whereby you measure the fuel flow of each injector individually. Since your injectors are new, any anomalies would probably be from the FD.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-23-2006, 04:19 AM
