Porsche-poor's Avatar
Oil temperature sender question
Seems that little oil leak I have is the oil temp sender, cause the gauge no longer works like it should. It never goes to zero and never gets very far above the white outline. The leak is not that bad is this something I need to address now or can I put it off till I am forced to drop the engine? Or is it possible that the wire has come loose?
Dave
'79SC Targa
'2021 CRV
Old 06-21-2006, 07:21 PM
DavidI's Avatar
David, the oil temp sender is actually easy to change (based on the belief that you have a 79SC). I think the set of the sender and numeric dash guage is about $75 from PP.
It is about a 30 minute job, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 06-21-2006, 07:36 PM
David, you talking the one at the front of the engine near the breather hose? Thats the one that is leaking.
'79SC Targa
'2021 CRV
Old 06-21-2006, 07:42 PM
DavidI's Avatar
David, post a picture of the part you are referring to. If it is the temp sender, it is a very simple process. It does not require anything more than unscrewing it and replacing it with a new one.
You also want to make sure that the guage and sender match. If not, you will not get an accurate reading. I suggest you also buy the dash guage with the numbers on it. It is an inexpensive, yet practical upgrade.
After you post a picture, I can give you a better assessment, David
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 06-21-2006, 07:47 PM
the little red guy about center of the picture. its right up there next to the t-stat. Bently book says thats the oil temp sender. is that it or is the sender that feeds the factorry gauge else where?
'79SC Targa
'2021 CRV
Old 06-21-2006, 07:53 PM
More digging into the posts here on the site have led me to think two things.
1. The bentley book is wrong and the sender is on the rear of the engine to the right of the fan.
2. The gauge is not busted its just not a great indicator.
Dave
'79SC Targa
'2021 CRV
Old 06-22-2006, 08:02 AM
The pic you posted is the oil pressure sender for the warning light on the dash.
The temp sender is located by the fan at about 5:00. The oil pressure sender for the gauge is right next to it and is a small cylinder about 1 1/2" in diameter and 2" tall.
The pressure sender you pictured is notorious for leaks, either the sealing ring under it or from the plastic / terminal junction.
At least this is how it is on the 2.7, I don' think sender locations changed on the 3.0.
Old 06-22-2006, 08:12 AM
Work in Progress
Rich76_911s's Avatar
Dave
1. Is correct the oil temp sender is just to the right of the fan housing.
2. That could also be correct? ? ?
I am 95% sure that this is the oil temperature sender:
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Rich, the red arrow is pointing to the temp sender, the part next to it to the right is the pressure sender for the gauge I refered to above.
Old 06-22-2006, 08:37 AM
Somatic Negative Optimist
Gunter's Avatar
Porsche-poor:
An easy mistake:
There is an "Oil Pressure Switch" AND an "Oil Pressure Sender".
The switch (Next to the breather cap) actuates the warning light in the dash.
The pressure sender (Next to the right of the fan post) actuates the gauge to show actual pressure.
The "Oil Temperature Sender" is as indicated by the above picture.
If the oil pressure switch leaks, it can be replaced with the help of a light and mirror and patience.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 06-22-2006, 09:51 AM
Gunter:
My wife would say I have two of the three items, the mirror and the light.
Thanks guys.
'79SC Targa
'2021 CRV
Old 06-22-2006, 10:05 AM
