-   -   SOS - did I install the pilot bearing the wrong way? (http://forums.pelicanparts.com/porsche-911-technical-forum/278728-sos-did-i-install-pilot-bearing-wrong-way.html)
cantdrv55 04-22-2006 07:17 PM
I have an early SC motor (78 - 79) so the pilot bearing doesn't have the three bolts that connect it onto the flywheel. Instead, mine has to be pressed in. I can't seem to find a good pic of this so I had it pressed in the way I thought it should go, but now it looks wrong to me. If you know for sure, could you chime in? Below are pics of what a machine shop didfor me. Is the pilot bearing pressed in the wrong way around?
http://forums.pelicanparts.com/uploa...1145758560.jpg
http://forums.pelicanparts.com/uploa...1145758595.jpg
http://forums.pelicanparts.com/uploa...1145758628.jpg
http://forums.pelicanparts.com/uploa...1145758658.jpg
john walker's workshop 04-22-2006 09:52 PM
that's correct.
cantdrv55 04-22-2006 09:55 PM
Sorry John. Did you mean that it is installed correctly as it is or that I installed it the wrong way? Thanks in advance.
Eagledriver 04-22-2006 10:08 PM
It is installed correctly. It has to be pressed in from the side that faces the crankshaft. You can see the collar on it that goes into a recess on the side that faces the crankshaft. Don't forget to grease it.
-Andy
cantdrv55 04-22-2006 10:15 PM
Thanks guys!
vash 04-23-2006 12:22 AM
sweet! see you in the AM. get tylenol ready...
