stock muffler tip replacement, my .02
Hi,
I decided to replace the stock tip with a new black one. The old tip is OEM and no longer black and has been ground away on the bottom. I found that by using a Dremel with the cutting disk, the old tip was easily removed. Safety glasses are a must for this one. http://forums.pelicanparts.com/uploa...1145759344.jpg Once the tip was cut along the bottom it split easily and came right off. I was careful not to cut to deep and hit the actual inner muffler tip. http://forums.pelicanparts.com/uploa...1145759418.jpg I used a wood mallet and a rag covering the new tip and it was back on in no time. http://forums.pelicanparts.com/uploa...1145759463.jpg SmileWavy I hope that this can help someone else in the future. Dave |
Nice job!
ianc |
Looks good. One of my pet peeves is the crappy looking exhaust tip on the 911's up until 1990. They just look wimpy. I like the aftermarket versions much better. It gives the car a more purposeful look to the rearend.(That is what most people see anyway!!!.)
I've been meaning to do this project but I thought the tip was welded on. I'll try your method since I just got a rotozip for Christmas.
Thanks for sharing. |
Nice job,
I was wondering about something similar. I'm getting a new M&K muffler but in all the pictures I see the tip just looks like nothing more than a piece of stainless pipe cut to size. I was wondering if anyone had any ideas or products to provide a more finished look. I know Fabspeed makes a nice tip but I'm not sure how it would fit and I don't think it would align well with the M&K http://forums.pelicanparts.com/uploa...1145893557.jpg |
Kilodawg
I have a nice Meg's oval 2.5 inch tip I won't be using. You can have it for 20.00 plus shipping. It cost about 35.00 new. NIB |
Another way to get your exhaust tip off
So I found the dremel and had one cutting disc that was used. Per Slodave's technique, I tried cutting the exhaust tip and it wouldn't cut. Since the rolled edge at the bottom of my tip was worn off (PO had a steep driveway) I tried cutting the tip off using a tinsnip. I started it but the jaws of the tinsnip was too large. I jammed a screwdriver between the muffler tip and the exhaust tip and the tip metal would rip pretty easily by using a rocking back and forth motion using the muffler tip as a stationary point for leverage. http://forums.pelicanparts.com/uploa...1146355363.jpg Here's a pic with the tip off next to the new one. They were the same length. http://forums.pelicanparts.com/uploa...1146355472.jpg I used a hammer and piece of wood to pound in the new tip here http://forums.pelicanparts.com/uploa...1146355527.jpg Another project off my list :-) Hope this helps someone. |
An old post, but I just wanted to share that it was helpful to me. I probably would have gone to a muffler shop if I hadn't seen the info posted here. Thanks!
I used the cutters shown in the picture to get a cut started without cutting the inner tip...then was able to rip it further by "grabbing" one side of the cut with the cutters and tearing away. I continued to use the cutters and a flathead to get it off. It was a little harder to tear than an aluminum can. I don't have a rubber mallet so I just used the first thing I could reach...some cardboard. I think it all took less than 10 minutes. Thanks http://forums.pelicanparts.com/uploa...1184009790.jpg |
| All times are GMT -8. The time now is 04:21 AM. |
