84porsche's Avatar
Send a message via Yahoo to 84porsche
Rear Seatbelt Bolt Removal Help!!
I have been trying for several hours to remove the rear seatbelt bolts and they seem to be locked in. I know its a 17mm and I have tried several different sockets as well as vice grips, tapping the bolt, spraying WD40 trying to loosen the bolt and to no avail. I need some advice to try and get these seatbolt bolts out. I got both the receptacle bolts out but for the life of me can't seem to get the seatbelt retractor bolts out. The left side is stripped or close to stripped. I can't get a socket to stay on it but can still get the vice grips on it. Any help is greatly appreciated.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 05-21-2005, 06:27 PM
Hmm....you "know" its a 17 mm , huh?....
Funny...all cars....even Euro....use seat belt bolts that are US thread 7/16-20 fine pitch...don't know what "head " size this uses....but it won't be a 17mm. Might be close.
If the hard-to-remove bolt is the inboard side...this can be seen from under the car. Maybe spray some PB blaster on the exposed portions of the thread that can be seen from below ( inboard sides).
In any case, WD-40 is worthless as a liquid to help budge tight bolts. Use PB Blaster, or Kroil or Wurth Rost-Off. Nothing else works.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-21-2005, 06:43 PM
84porsche's Avatar
Wil,
Thanks for the help. I have been using a 17mm and it removed the other 2 bolts and it looks like that might be part of my problem. I just got the right one out with the help of a friend but the left one looks beyond help.
Chris
2003 VW Jetta GLI
Old 05-21-2005, 07:04 PM
If the head is not too boogered up try to find the "correct" tool ( size) and try again.
Sometimes, a quality part like from Snap-On will make a difference in situations like these... either a socket or a wrench, etc. Maybe even a flare nut wrench so you have some extra "grip".....
I'd try a flare wrench and a hammer..but be very careful in striking metal with metal. Use safety eye glasses and maybe tape the wrench where it's hit.
Yeah...the outside one.....no access from below....
Wil
Wil Ferch
Old 05-21-2005, 07:11 PM
Air would do it.
pat
18,000mi a year 84targa
Old 05-21-2005, 07:38 PM
84porsche's Avatar
I just purchased a damaged bolt nut remover set from Sears and I am hoping that this will get it out. I got grip on it now but need more strength to get it out. I will try tomorrow and hope for the best. Thanks for all your help again.
2003 VW Jetta GLI
Old 05-21-2005, 08:48 PM
Eric Coffey's Avatar
Yeah, the "reverse easy-outs" can be life savers.
These:
Plus a good 1/2 drive ratchet (and maybe an extension) should do the trick.
Old 05-21-2005, 08:55 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
I had to use an impoact wrench on mine and even then they were bears. Yes, the head was ultimately ruined.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 05-22-2005, 12:35 AM
I was lucky. I got mine out with only a couple of busted knuckles. BTW once I get them out I put in new bolts to fill the holes.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 05-22-2005, 07:23 AM
84porsche's Avatar
Its finally out. Thanks to Sears, their Craftsman Line of Tools and you guys. I need to join their tool club if they have one. Eric, that is the exact set I purchased all for one bolt but I have feeling if I continue to work on my car, I will be needing these again.
jtratza - Did you put new bolts in as a place holder?
2003 VW Jetta GLI
Old 05-22-2005, 10:13 AM
I put bolts in to keep the dirt out and I felt like heat was coming in through them. Could have been my imagination.
Old 05-22-2005, 11:14 AM
930yyc's Avatar
Serious Question pardon the ignorance here,
Would the Sears Craftstman set pictured above work on a set of bolts that have completely rounded off heads?
I uncapped the rear bolts today to remove/install belts for DE and discovered some previous owner/repair nonsense in that 3 of 4 bolts are completely or very near completely rounded off.
I need to know which specific tools / method for the job to get these 3 bolts out.
They also appear to be overtorqued well into the plastic with very little to head to be seen, few mm.
Thank you,
-Ivan
'86 911 Carrera ROW
Old 04-23-2006, 03:04 PM
Send a message via AIM to rtoms
ivan invest in vise grips ahha and some brews and band aids for your hands when you slip off an bang it up
86' 911 coupe
Old 04-23-2006, 03:08 PM
Thank you,
-Ivan
Yes they will probably work, and use a breaker bar to help get things started with downward pressure on the socket head.
Old 04-23-2006, 04:26 PM
When I removed mine, I had to break out the 1/2 drive Snap-On impact sockets. I didn't use air, but the thing you have to realize is that you can't use a 12-sided socket or wrench (such as yours) on a bolt head that big that's on that tight....they use an epoxy at the factory to seal the bolt in. You have to use a six-sided socket (1/2 inch drive and a breaker bar). If it's too buggered-up, you'll have to use those easy-out bolt extractors.
'82 911 SC
Old 04-23-2006, 04:40 PM
