Normal Residue on AC Compressor?
Have a look at these photos... is this black, oily dust normal for the AC compressor. I suspect it's just like brake dust, but from the magnetic clutch. Everything seems to work fine and the compressor doesn't make any noise.
http://forums.pelicanparts.com/uploa...1145819586.jpg http://forums.pelicanparts.com/uploa...1145819610.jpg It doesn't necessarily indicate a problem with a shaft seal or anything like that ? (he asked optimistically). |
After the A/C is charged, as the hose is removed from the high-pressure line on that side, a discharge of the refrigerant under pressure happens. It deposits a light coating of oil on everything in the area that dust sticks to. That's probably all it is.
Oooh, Good answer! I like it. I'll just clean it up and hope it doesn't come back then.
Derek |
It could also be particles from your belt.
Look for dirt stripe on the underside of the engine decklid in line with the compressor pulley; if you see one you may have a compressor shaft seal leak.
| All times are GMT -8. The time now is 06:40 AM. |
