Clutch release fork - Do I need one?
How do you know if you need a new one of these?
http://www.pelicanparts.com/cgi-bin/smart/imgdsply.cgi?pn=91511671201-M260 Engine is out and I am doing the clutch (915 Transaxle) as well as a general clean up and new seals everywhere. My release fork looks good with no wear but I am wondering what determines if it needs replaced. Help? Thanks, Steve |
If there is not excessive wear and no cracks (inspect it carefully) then reuse it.
I replaced mine because I read somewhere that it's a good thing to do while you're in there. The old one had nothing wrong with it though so I think I may have just wasted $95. I'm with Jim. Inspect it very carefully and reuse it if all looks good.
I just splashed it with thinner to help find a crack.
mine was good, so I reused it.
the tips get notches worn in them from pulling on the T/O bearing, and they tend to crack, so there's two reasons.
I had my whole clutch re-done after 20,000 miles because my fork cracked. Save yourself some headache.
Doug |
Replace it!
I had a new clutch and T/O installed 5k miles ago. Now I can't shift into 1st and we think a broken fork is the culprit. |
In a 1973 T with a standard pressure plate and nominal engine (130 or 140 horsepower tops) the shift fork is not a highly stressed component; if it isn't worn or cracked it can be reused. Money would be better spent putting in new fuel lines.
| All times are GMT -8. The time now is 12:19 PM. |
