-   -   partial engine drop (http://forums.pelicanparts.com/porsche-911-technical-forum/279157-partial-engine-drop.html)
88911coupe 04-25-2006 06:26 AM
partial engine drop
OK...I'm going nuts here. I know I had and article that outlines a partial engine drop but I can't find it anywhere (moving is a PITA). This is different that the article on Pelicans tech section which involves removing oil lines and the main engine bolts. This article was just for dropping the tranny side a bit to get access. I can't find it with a search, in either of Waynes books or Bentley. Does anyone know the article I'm talking about? It's for an 88 3.2 BTW.
This is in case I can't get the slave cylinder disconnected from the hydraulic line.
TIA
plymouthcolt 04-26-2006 02:30 PM
Guest Technical Article: Partial Engine Drop by Walt Fricke
88911coupe 04-27-2006 02:59 PM
Thanks for the link but that's not the one I was looking for. The one I'm talking about is to just drop the front and I manged to just wing it and it worked fine. I'm sure I'll find it as we uppack! I can probably do this in my sleep now...I was making it a lot more complicated than it was. What's scary is all those wires/lines/connections that look like they could be damaged in a partial drop but it appears most of them run NEAR the tranny but aren't actually connected to it.
