-   -   Can you delete the A.A.R. (http://forums.pelicanparts.com/porsche-911-technical-forum/279329-can-you-delete-r.html)
Turbo-Mag 04-25-2006 07:43 PM
I live in Hawaii and just purchased my first Porsche:D It's a '76 with a '78 3.0 motor.
I wanted to know if I could get rid of the Auxiliary Air Regulator and associated hoses and just add a crank case breather box.
I havn't taken apart my wiring harness yet so I am not sure if the wiring is complete. The CSV is plugged in and so is the AAR, however there is no Thermotime switch. So I don't know if I need the AAR. I would like to get rid of it.
Any help is appreciated:)
Paulporsche 04-25-2006 08:09 PM
You probably don't need it, living in Hawaii. RarlyL8 says he has his removed, and says the engine works just fine. I think he is in the southern US.
Turbo-Mag 04-26-2006 12:28 AM
Thanks Paul, If anyone else has input, I would like to hear it:D
RarlyL8 04-26-2006 10:09 AM
Mine is gone but the engine is a 930.
I had a 3.0L SC back in Illinois so the AAR was left intact. I can't say what adjustments may need to be made on that engine (if any) to compensate for the removed part. All the device does is increase the idle of a cold engine after start-up.
Turbo-Mag 04-26-2006 10:35 AM
Thanks for the info RarlyL8. I'll be leaving it out. I am re-doing the wiring harness this weekend and I'll at least leave the connections available. I hope to have my turbo set up complete in the next couple of weeks. Then it will be time to enjoy.
Do you have pics of your '78 w/ the modded 930? it sounds sweet
RarlyL8 04-26-2006 10:44 AM
Pictures? Your kiddin' right? HA!
http://forums.pelicanparts.com/uploa...1146073384.jpg
http://forums.pelicanparts.com/uploa...1146073425.jpg
David 04-26-2006 10:58 AM
I took mine off my 78 280Z and I just had to feather the throttle for a few seconds when it was cold. I'm not planning on having one with my new EFI setup.
Rufblackbird 04-26-2006 02:46 PM
Holy crap, a new guy on Pelican in Hawaii! WOW! ;)
Not sure on the AAR though...I've always had mine in...haven't had to mess with it since it's still working.
Turbo-Mag 04-26-2006 06:57 PM
WOW, Brian that '78 is a beaut...
and yea, Hawaii... gotta love the year round beautiful weather:)
ianc 04-26-2006 10:19 PM
I would leave it. What is the reason for deleting it? The cost of the new part? If you can't afford a new\used AAV, then I see trouble in your future. The part is there to perform a function; why not leave it as the factory designed it?
ianc
diabolos88 04-26-2006 11:50 PM
you just dont NEED the AAR, AAV, Decel Valve, Thermal time switches, air pump, etcetc, most of this stuff is purely for passing the smog/emissions tests or for assisting a cold start in colder climates. You DO need the WUR though so leave that. There are lots of threads on this subject, I just got done removing all my "junk" this past weekend :)
More space for doing your tune-ups and cleans up the engine bay very nicely.
ianc 04-26-2006 11:57 PM
You need them. If, as in CA, it gets into the 40's-50's and is wet at night during the winter, you need them. Who's to say where the car will end up in future? Not to CA if it's had some of its injection pieces removed. They certainly don't make the car run any worse (and will quite probably make it run better), so why not repair them properly?
ianc
Edited to say: I guess I wasn't wholly clear. I would leave out some stuff mentioned by diabolos but use others. I would use the AAR (for a steady idle when cold), AAV (for increased air at startup), and the thermotime switch (which triggers the cold start valve, which you should also have).
You can have the rest.
village idiot 04-27-2006 12:47 AM
Except for the 40 straight days of rain that we had recently:D
diabolos88 04-27-2006 01:13 AM
Ianc' sactually right, if you live in CA, then yes I agree totally with what he stated.
RarlyL8 04-27-2006 06:02 AM
He lives in Hawaii. Not much chance that car is gonna end up in California. I don't build/mod my cars with the home town of the next owner in mind. If it ends up in California you have bigger problems than a missing AAR.
Paulporsche 04-27-2006 06:09 AM
Why not save the deleted components in case the next owner needs them?
Turbo-Mag 04-27-2006 06:44 AM
Well the stuff comes off 4 sure and will be boxed up in the shed. Might use the CSV with my turbo set up though:D
V.I. last months rain was jus' too much;)
Mysterytrain 04-27-2006 06:49 AM
Why not backdate the AAR? Remove it and the plumbing and add that cool hand throttle between the seats!
john walker's workshop 04-27-2006 08:00 AM
early turbos have a hand throttle AND a AAR. what's the theory on that i wonder? i removed the AAR on my 77 turbo and just use the hand throttle. works fine and cleans up the area.
Turbo-Mag 04-27-2006 09:34 AM
Do you have a picture of the hand throttle and what advantage does it give?
Jim Williams 04-27-2006 03:34 PM
I'm not recommending what you *should* do, but here's what you *can* do. You *can* remove the AAR and AAV, and use the accelerator pedal to slightly open the throttle plate as you start the car, then slowly feather it down as the engine warms and the idle speed comes up. Or if you have a hand throttle, you could use it instead. I think the '75 was the last year for the hand throttle, but John Walker says his Turbo has one. The Factory put the AAR and AAV in so they could eliminate the hassle of folks having to deal with the hand throttle.
You can also remove the decel valve, but may have problems with the engine stalling in some cases, like snapping off the throttle and depressing the clutch when coming up to a stop light. The factory put it there to prevent the mixture in the manifold going too rich when the throttle is suddenly closed, resulting in an increase of emissions. Some people block it off because they like the way the engine behaves this way, using the engine to brake.
The CSV is the only way to get a combustible mixture into the engine without a lot of excessive cranking, pretty much regardless of the outside temperature. The only other component for getting fuel into the manifold is the air flow sensor/fuel distributor, and the air drawn onto the engine at cranking speeds is pretty low. Thus the air flow sensor doesn't raise much at cranking speeds.
Rufblackbird 04-28-2006 02:32 AM
screw the AAR, screw CIS, and just go EFI. Cleans up the engine bay quite well, and will probably work better with the turbo :D
that 41 days of rain sucked....bad. Especially since my targa leaks a lot. :mad:
oh yeah, for those who aren't in the club, join and come out to play! www.pca.org/hi
