-   -   Rev counter check when out of car? (http://forums.pelicanparts.com/porsche-911-technical-forum/279428-rev-counter-check-when-out-car.html)
elflamo 04-26-2006 12:02 PM
Hi all, after a long search I found and bought a 2.4S rev counter on eBay. Now, unfortunately it fell down the stairs and I have no means of checking whether it still works because my car is in parts due to restoration.
Is there a way to check whether a rev counter works without attaching to the engine??
Dennis
Early_S_Man 04-26-2006 02:28 PM
Dennis,
You can test the tach on a bench by building my 'junk box calibrator' ... and using it as a pulse source for checking the tach at 1200 rpm and 2400 rpm.
http://forums.pelicanparts.com/uploads/tach_calibr.jpg
elflamo 04-26-2006 11:37 PM
Excellent! I“ll take this diagram to my local electronics shop and see what they can do.
Many thanks
Dennis
elflamo 04-26-2006 11:52 PM
Early_S_Man, FMMI, but there seem to be quite some connectors on the tach. AFAIK, two are for the turning signal, but where do the others hook up to this diagram:
- “Output“ goes to signal in on the tach I guess, can you tell which one that is?
- any other link between tacho and this diagram I need to make?
I guess what I“m saying is that it would help me if the tacho is in this diagram as well.
Many thanks again!
Dennis
