}{arlequin's Avatar
screen for front oil cooler?
what do you guys use for the protective screen of the front mounted cooler? how big, or how small, do the holes have to be? thanks.
dave
1973,5
Old 04-27-2006, 09:51 AM
Par911's Avatar
what you talkin bout willis?
Old 04-27-2006, 10:13 AM
}{arlequin's Avatar
ok, let me slow down for you....
the.
protective.
mesh.
screen.
that.
goes.
in.
front.
of.
nose.
cooler.
to.
protect.
it.
i need to get one and don't know what type/kind is best to work with. different sizes of mesh screens... airflow vs. protection issue... etc etc.
dave
1973,5
Old 04-27-2006, 10:22 AM
Par911's Avatar
I'll take photos of mine if you want.......I'll call you later. Remind me.
Old 04-27-2006, 10:27 AM
jdowty3's Avatar
Someone on the board had inserted SS screen in the valance cut out to protect their oil cooler. I think the post said they would sell some cut to fit your needs.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 04-27-2006, 10:37 AM
Pegasus Racing (among other sources) carries stainless steel mesh in a variety of mesh size - very rigid. I wouldn'ot recommend chicken wire or other galvanized mesh since they're more susceptible to a hard rock hit. Avoid perforated designs as the airflow characteristics aren't too great.
Sherwood
Old 04-27-2006, 10:40 AM
I am using a part of a plastic deck lid grill.
In the picture I was deciding which lights to use (Cibie Tango or Oscar I decided Oscars).
Old 04-27-2006, 10:46 AM
Friends of Warren
911teo's Avatar
I went to McMaster Carr
http://www.mcmaster.com/
You can really get anything you want.
I ordered the following
Plain Steel Standard Grade Woven Wire Cloth 8 X 8 Mesh, .025" Wire Diameter, 36" Width
Cost me less than $10 shipped. So really you can choose different mesh and finish so that you get exactly what you are after.
Matteo
Warren RIP
www.impactbumpers.co.uk
Old 04-27-2006, 11:34 AM
Friends of Warren
911teo's Avatar
I just customized an order
Material Type Stainless Steel
Stainless Steel Type Type 304
Form Woven Wire Cloth
Square/Rectangle Size .1"
Mesh Per Inch Range Coarse Mesh
Mesh Per Inch (Coarse) 8 x 8
Percentage of Open Area Range 60 - 69
Percentage of Open Area 64.0
Wire Diameter .025"
Grade/Type of Woven Wire Cloth Milling Grade
Shape Sheets
12"x12" = $6.25 each
12"x24" = $12.52 each
36"xcut to length = $6.26 per sq ft
Matteo
Warren RIP
Old 04-27-2006, 11:38 AM
Cory M's Avatar
Thanks or the McMaster-Carr tip, I should've thought to look there. I was ready to order some mesh from Pegasus, it was about $30 for a big piece of mesh but the shipping was over $20 so I didn't order it; I should save a few buck going with McMaster.
Old 04-27-2006, 11:45 AM
I use a custom plastic grill similar to the rear deck equipment and expanded alumium (painted black) behind. Has proven to be very durable and allows quite a bit of air to pass.
Warren & Ron, may you rest in Peace.
Old 04-27-2006, 12:34 PM
}{arlequin's Avatar
thanks guys
dave
1973,5
Old 04-27-2006, 01:53 PM
