Where can I get this fitting
Im trying to look for a fuel rail adaptor fitting so I can run my fuel pressure guage. I've bought a fuel pressure guage, but none of the fittings work. Can someone guide me to a site that would have the correct fitting adaptor.
I think the stock size is a 14mm x 1.5. |
Summit or Pegasus Racing, McMaster or BAT Inc. All are on the net.
Not having too much luck. Im finding fittings just not the one I need.
Can someone verify the fuel rail fitting size on an 86? |
I would try one of the larger industrial hydraulic shops in the area. Since you are in the oil patch, there should be some very good ones in the area.
Most have a wide assortment of fittings and you should find one that works. If not, they may be able to braze something for you. |
Just like Mike offered, but a little more specific.
Go to www.batinc.net, place a call and explain what you are trying to do. He'll help. You might make a T from AN fittings, but they have the adaptors you'll need. Good luck, Doug |
| All times are GMT -8. The time now is 03:42 AM. |
