-   -   What do you think of my custom strut tower braces? (http://forums.pelicanparts.com/porsche-911-technical-forum/279544-what-do-you-think-my-custom-strut-tower-braces.html)
FirstGen 04-26-2006 09:59 PM
Just made these today, I think they turned out pretty nice...http://forums.pelicanparts.com/uploa...1146113947.jpg
FirstGen 04-26-2006 10:00 PM
closer pichttp://forums.pelicanparts.com/uploa...1146114032.jpg
FirstGen 04-26-2006 10:01 PM
last onehttp://forums.pelicanparts.com/uploa...1146114077.jpg
bigrubberjeep 04-26-2006 10:51 PM
Looks good! but why 2?
FirstGen 04-26-2006 11:08 PM
I dunno, why not? Extra strength...
IROC 04-27-2006 04:48 AM
Maybe you could really open up the rear one and tighten up the front one and get some more toe in. :>)
Mike
trj911 04-27-2006 05:33 AM
Looks like they should work as good as the store bought ones. What are they made out of? How much do they weigh? One may be sufficient to do the job and if so the second one is only adding weight.
kwm 04-27-2006 05:49 AM
Do you have a better shot of how you connected the ends to the towers?
FirstGen 04-27-2006 06:50 AM
They are made from 3/4" thick 6160 solid aluminum rod with 10mm heim joints on each end. On side is right hand thread and the other is left hand thread so that it can be adjusted without removing the end. It is just attached with a longer bolt through the heim joint. Not sure what the weigh but not much a few pounds maybe.
JohnJL 04-27-2006 07:28 AM
I respect the DIY approach.
I think you might gain some stability/rigidity if you could drop tehe passenger side of the forward one to the brake master cylinder mounting bolts or triangulate to another ridid point.
FirstGen 04-27-2006 09:49 AM
I agree, I thought about this and might consider doing that at a later point.
911pcars 04-27-2006 10:56 AM
I think your DIY approach is as good as any commercial strut-to-strut setup. However, you might have the same rigidity using a single bar, but with a more difficult-to-fabricate mounting bracket on each strut tower.
MHO,
Sherwood
http://members.rennlist.org/911pcars
rnln 04-27-2006 12:45 PM
I guess you must be a machinst, to do the cross thread :)
nice work.
