901 shifter for 915?
Will a shifter assembly from a 67 912 with a 901 4sp work with a 79 915 5sp upgrade?
Old 04-27-2006, 09:35 AM
Since the 915 shifter can work with a 901 gearbox, it should also work the other way. But why?
Sherwood
Old 04-27-2006, 10:58 AM
3 restos WIP = psycho
kenikh's Avatar
I believe that the old 901 shifter was a stock fitment for the 915 transmission in 1972. The "915" shifter came online in 1973 if I remember correctly. Shouldn't be a problem, then.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-27-2006, 11:04 AM
I'm replacing my 901 with a 915 because I broke the spiders in the 901 the 915 should be just strong enough for a Ford 302. I know a 930 is a lot stronger but with a few mods the 915 will work.
lars
Old 04-27-2006, 11:52 AM
shifter
i don't think it will interchange..the reverse lockout will not be compatable..get the correct shifter for the trans type
Old 04-27-2006, 01:21 PM
JWest's Avatar
It will fit and shift the transmission, but the spring lockout will be on the 1/2 gears rather than 5/R.
The '72 shifter for the first year of the 915 is much like the 901 shifter you have now, but the spring lockout was changed to the other side for 5/R.
Bottom line - it will work but you will have to be vey careful to not hit reverse gear.
James
JWest Engineering
Old 04-27-2006, 01:36 PM
