Bilsteins vs. Konis
I had my car stripped and repainted over the winter and also upsized my wheels to 16x7 Fuchs. The next project on my list is lowering to euro height and adding a turbo tie rod kit, alignment and corner balance. My car currently has Koni shocks (original) that probably could stand to be replaced.
Most things I have read said that the standard “upgrade” is to go to Bilsteins. Of course, this means I would need to upgrade my strut assemblies as well which pushes the price pretty high for the project.
My car is used for street driving and weekend runs on public roads. I don’t track it and don’t plan on tracking this particular car. The car has 80,XXX original miles on it.
What are peoples thoughts on the two shock types? With the driving I plan to do, will I notice the difference between new Konis and new Bilsteins? Is the upgrade to all new strut assemblies worth the extra money?
Thanks!!
Obligatory Pic:
Jesse LaDousa
1975 911s Targa - Silver Anniversary
Modell Nr. 198
Old 04-27-2006, 08:25 AM
IROC's Avatar
I'd stick with the Konis. I've never had Bilsteins on my car, but have had Boges and Konis and the Konis are perfectly fine. Especially for your application, I would suggest the standard Koni "reds" - don't go for the yellow sports. Overkill and a bad match for stock torsion bars.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-27-2006, 09:18 AM
Elombard's Avatar
You might just crank up the Konis a couple of notches, may not even need to be replaced?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-27-2006, 09:20 AM
IROC,Why are the yellow sports a bad match for the T bars.
I like the flexability they provide in handling/ride, and am pleased with them ??
just curious.
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 04-27-2006, 10:07 AM
Thank you - you confirmed my suspicion that I can stick with Koni's!
Jesse LaDousa
Modell Nr. 198
Old 04-27-2006, 10:53 AM
IROC's Avatar
just curious.
I personally think the valving of the sports is too stiff for the spring rate of the stock torsion bars, but maybe that is just my personal opinion.
It is important when you get right down to it to match spring rates and shock valving, but there's nothing to say you can't use sports with stock torsion bars.
Mike
Mike
1976 Euro 911
Old 04-27-2006, 12:14 PM
Mike,
I appreciate your feedback.and admit to not having a handle on.
It would be interesting to have a 911 suspension guru drive my car with the Konis and compare with Bilsteins.I dont think I could tell the difference...yet
I have had the sports on for about 6 -9 mos and no complaints on the street.
The blind shock test of 2006
HB Kramer
Old 04-27-2006, 01:18 PM
