relkceb's Avatar
Help Removing rotors on 87 930
Can anyone tell me how I get the dust cover off of the front axle I am trying to replace my rotors. I found that it is not the same as a non-turbo(a simple dust cap). And why does it have threads in the middle hole.
Old 04-27-2006, 08:09 AM
Automotive Monomaniac
Emission's Avatar
It is a b*tch to get off.
It is threaded so you can put a tool in there for some leverage - I used a bolt and rigged my own "extractor" tool.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 04-27-2006, 08:16 AM
relkceb's Avatar
so it just pops off like the others
Old 04-27-2006, 08:24 AM
Nine9six's Avatar
Yes it does...
I used two opposing screwdrivers and worked it to death. I did this after the stupid friction welded threaded center popped off when gently using a slide hammer tool.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-27-2006, 08:28 AM
Tut Tut is offline
There are other threads on this. Put a U clamp around the dust cap and then use the clamp as a place to pry on to get the cap out.
Tut
'87 Carrera coupe
'08 BMW 535 xiT
Old 04-27-2006, 09:02 AM
Slippery Slope Victim
NY65912's Avatar
It is a royal PITA. Like stated above, I just keep working it with a screwdriver prying all around until it gets loose and pull it off.
Good Luck
MikeČ
1985 M491
Old 04-27-2006, 09:08 AM
mark '87 930's Avatar
i bought $8 worth of hardware which included a threaded rod to fit the welded nut, and then a few washers and a nut for the rod. I used the leverage of a steel plate on the lug botls as I tightened the nut against the plate.
Took no time at all and then.. pop.. off it goes.
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 04-27-2006, 09:10 AM
i bought a threaded rod and use it in conjunction with a slide hammer. Makes it real easy to pull off then.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 04-27-2006, 09:36 AM
NY65912's Avatar
Ah so........very good ideas gents! I shall be modifying mine.
MikeČ
1985 M491
Old 04-27-2006, 09:45 AM
I welded a bolt to a piece of round stock to make a "T" handle, so I can yank it right off.
Old 04-27-2006, 10:15 AM
DP935 member
kycarguy 935's Avatar
I use a custom made puller-slider that I bought about 10 years ago but you could make one yourself also.
The U-clamp will work on a 911 but NOT on the 930-911 turbo. The 911 dust covers stick out a bit whereas the 930's do not.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 04-27-2006, 11:15 AM
U clamp method DOES NOT WORK....the TURBO has the dust cover RECESSED.
U-clamp works for NON TURBO where there is clearance to get a U-clamp attached...
And...this may not simply POP off....I broke ( ! ) a slide hammer trying to get a turbo, bullet-proof cap off !!!!!
Hands-down BEST way for a non-turbo --> Removal of Dust Cap on Frt wheels bearings
Turbo version / problems / pics ---> Trying to get front wheel bearing dust covers off*&^%!!
-Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-27-2006, 01:29 PM
heiliges blechle!
I needed to get the dust cap off my '84 turbo-look last weekend. I started off with a 3 lb. slide hammer and it's jaw broke on the third hit. So I bought a 13 lb. slide hammer and modified one of the pulling hooks to fit around the bolt I had screwed into the cap. The cap wouldn't budge at first so I kept hitting it harder until the threaded piece pulled out of the cap leaving a ~1/2" hole in the dust cap - the pulling hook was also bent some. I had a gear puller and took the jaws off it and reversed them so the fingers were pointing out and put two of them in the hole and bolted them together. Then I wrapped a chain pulling-attachment around it and started hammering away. I broke the welded chain twice and then the puller jaws pulled through the steel cap peeling the metal back. I turned the puller 90 degrees and had at it again... I was about to give up and then one fateful hammer the cap just popped out. I think it was the first time in 22 years it had been removed. A replacement dust cap is $59.75 with shipping...
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 11-27-2006, 11:26 AM
heiliges blechle!
Here is a pic of the aftermath... You can see the pulled-out threaded piece at the top and the chain that broke. The puller jaws still inserted into the hole and the chain wrapped around it. I got my replacement dust cap in a week ago so this ordeal is over.
Old 12-10-2006, 09:22 PM
Home made tool for overly anal Porsche nuts like me:
"Removenderdustkappen" (2 part tool, note orange plastic hammer).
Old 12-10-2006, 11:44 PM
