UFLYICU
Don't forget to have a full alignment when you are finished with the ride height. All your cambers and toes will be affected.
FWIW, I re-indexed and set my ride height with Wil's calculator and used 29 degrees for my angle. I believe I used 2750lbs with my stock Carrera bars.
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 06-23-2006 at 03:21 AM.. |
Did that turn out to be 1.5 inches higher? Otherwise how much did you settle on. My car is in the same boat your was in, I don't know anything about setting height yet so the first time I doubt I will be able to do it myself but I would like to be able to ask for the correct to be made. Would a tire place that does alignments be at least qualified enough to raise it 1/2 an inch during an alignment?
1966 912, Carrera RS Clone 2.2L 911E(1970)CIS MSD
