defcon65's Avatar
Front spoiler as jack point?
I'm kidding because I'm loving all the replies to my other post. See you all back on page 3.
Joe
Old 04-26-2006, 09:27 AM
Paper Member
Rabble-rouser
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 04-26-2006, 09:45 AM
Thrasher's Avatar
Yes, use the spoiler in front, muffler in back.
Also, please be sure to raise/slam your decklid by the tail (if attached), push down your manual antenna by the topmost skinniest section, and shift your 901/915 as quickly and forcefully as you can muster.
I also find it is best to warm up my engine by redlining it from the start, but only after I've added a few extra quarts of oil above "full" - just to be sure.
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12)
Old 04-26-2006, 10:27 AM
Automotive Monomaniac
Emission's Avatar
I use the side mirrors.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 04-26-2006, 11:26 AM
wcc wcc is offline
wcc's Avatar
This is all GREAT advice and I'm bookmarking this thread for later! Thanks guys!
Bill
997.2
Old 04-26-2006, 11:32 AM
Adrenaline Junkie
Hayabusa's Avatar
Jack the whole car- saves time!
Old 04-26-2006, 11:34 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Not everybody can afford fancy tools.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 04-26-2006, 12:08 PM
lateapex911's Avatar
Now THAT is beyond amazing..
Darwin...where are you when you are needed?
(Do ya think the brainiac did a fissure study of each rock before placing them??)
The only "tragedy" that could result here is if the rocks don't collapse...or if he survives if they do collapse....
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 04-26-2006, 12:17 PM
UFLYICU
ZOA NOM's Avatar
You suppose he's checking the runout on his rear hub?
prc-racing.com
Old 04-26-2006, 12:24 PM
madmmac's Avatar
Does not work with cabs or targas:
Sunroofs are really easy as you can just open it and slide a chained railroad tie in.
Pour oil under both rear wheels.
Block and tackle centered above car in big beam.
Wrap large chain around tire and axle.
Run the chain through the block and tackle.
Thread the chain through both drivers and passenger opened windows and reconnect as close to roof as possible.
Start car, drop clutch and floor it. Pulls her right up.
Caution: May cause fender damage.
LSD's take a little more work though.
Hope this helps.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 04-26-2006, 12:56 PM
come on guys, everybody knows that it's much easier to just drive up a telephone pole guidewire at about 40 mph. Great under-car access. Also works for checking pans for rust while you're test driving a car.
Porsche
Old 04-26-2006, 01:30 PM
Wavey's Avatar
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 04-26-2006, 01:33 PM
Emission's Avatar
Originally posted by Wavey
I am speechless.
Old 04-26-2006, 02:05 PM
I've seen that before. Nice welder! Isn't that the gas tank right there?
At least the 4 x 4s aren't fracture prone, although the anchorig technique could use a little work.
Note the tailights...reflector strips!
Old 04-26-2006, 02:13 PM
UFLYICU
ZOA NOM's Avatar
prc-racing.com
Old 04-26-2006, 02:19 PM
Make Bruins Great Again
Por_sha911's Avatar
If you are going to jack up the front by the chin spoiler, then at least use a Cool Collar for safety. After all, you wouldn't want it to overheat now would you?
Joe
Old 04-26-2006, 06:01 PM
DW SD's Avatar
GREAT, informative thread! Highly recommend turning into a sticky - must - read for newbies.
I like to suggest opening the doors and then jacking up by the outboard most portion of the door. The extra leverage is your friend!
I had to learn all the good stuff the hard way, now it's all condensed down into one easy thread.
Great work fellas!
Doug
1971 RSR - interpretation
Old 04-26-2006, 06:12 PM
Front spoiler? That's just crazy talk. Everybody knows that the fog lights are the only safe lifting spot on the front of a 911, and the bumper pads in the rear.
Old 04-26-2006, 06:33 PM
Wavey's Avatar
Hmmmmmmm... bet those would be lighter than the "R" taillights.
Old 04-27-2006, 05:18 AM
Super_Dave_D's Avatar
Dont you jack it up by the tie rods??
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 04-27-2006, 07:46 AM
