What other car use M14/1.5 wheel nuts
I would like to get a set of steel nuts for the track and I would like to know what other cars will use the same wheel nuts.
Here in Guatemala the availability of Porsche parts is very limited and $$$$$$$. Thanks
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 |
Surprisingly, my 1993 GMC Z71 4 wheel drive pick-up uses the same lug thread size as the 911. I know because I used one from the truck to "seat" my longer studs.
Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now.... '86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Besides the correct thread you also need the correct ball seat.
on the left is the correct Porsche wheel seat, on the right the conical seat that BBS uses The best price I saw was on Rennlist in the classifieds. His were also cad plated, a big +in my book
Mario,
1971 - 79 VW Type II [or Bus, Transporter with front disk brakes] use the same spherical seat 14 mm steel lug nut as 911. The VW parts should be reasonably easy to get.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Could you not order a set of steel lug nuts from our host and have them shipped via USPS since they have a form of discount air shipping that avoids some customs cost.
FWIW, a 914-6 uses the same lug nuts.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
