-   -   88 brake light switch problem. (http://forums.pelicanparts.com/porsche-911-technical-forum/279939-88-brake-light-switch-problem.html)
pmajka 04-29-2006 05:55 AM
I have been having a problem with the hydraulic brake light switches. i need to press harder to get the lights on than normal street driveing requires...I am noticing some startled faces in the rear mirror more often. I hooked up a LED to show when the light comes on.
I have already replaced the topfront swtich, but not the lower rear. for those who dont know they are only 3 inches apart.
I also have not bled the brake fluid yet.
I am bout a cat hair shy of making my own mechanical swtich.
Seeking advice, but i am guessing people will say, drain fluid and report if there is any change.
jester911 04-29-2006 06:05 AM
You need to replace both switches. No need to bleed brakes if you are careful. I swapped both of mine about 2 years ago with no problems.
Oh Haha 04-29-2006 06:08 AM
Replace the other switch. How long ago was the fluid changed? Although the age wouldn't affect he operation, if it is low, it WILL affect them. I replaced my brake lights with LED bulbs. They come on a bit quicker than standard. How about your brake pads? If they are worn, you will need more pedal to activate the switches. I learned this little tidbit after my first track day. DOH!!!
EDIT: I had my wife hold the brake pedal down while I changed my switches last summer. I didn't have to bleed the brakes that way. Hold it down, replace the switches, still holding the pedal down, then release when the job is done.
Por_sha911 04-29-2006 10:26 AM
With all due respect to Jester, technically you don't have to bleed the brakes but unless you've done it recently then why not?!? It is a very cheap and easy maintenance on a very vital function of your car and it can't do anything but help. Don't forget to bleed the clutch also (a little more work but a good thing).
movin 04-29-2006 09:51 PM
I still say these switches can be defective from new because they are set to close at too high a pressure. I've found that different manufactures set the closure at different pressures when I had this problem with my old VW bug. Unfortunately there seems to be only one source for Porsche, so if they're crap, that's it. A mechanical switch makes sooo much more sense. Does anybody make an aftermarket conversion kit? It would be nice...
