ausgezeichnet's Avatar
Bolt Nut and Washer sizes
In looking at the PET catalog I see specifications for nuts bolts and washer like this. What do these notation mean? I know the M5 or M8 means it is a metric size and the 5 or 8 is the diameter. How do you know what the correct length and thread pitch should be?
Washer A 5,3
Lock Nut M 5
Hexagon-head Bolt M 8 x16
Thanks.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 04-29-2006, 09:17 AM
Nine9six's Avatar
You could always identify the thread pitch of the old one with a thread gage.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-29-2006, 10:09 AM
Not quite sure where you're going with the question....
M8 x 16 means a metric 8mm bolt that is 16 mm long under the head.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-29-2006, 11:09 AM
randywebb's Avatar
The nut designation must mean it fits an M5 bolt. There is a DIN and now I guess an ISO std. for the thread ptich. IIRC, rarely there will be a departure from that for special use fasteners.
No ideas about the washer designation -- where did you see that code listed?
Jim Sims is bound to know all about this - he might see your query and post something definitive.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-29-2006, 12:11 PM
Ok. Thanks. That answers one question. That means the thread pitch is not specified. Could it mean that the thread pitch is standard for a certain size of a bolt?
I found the washer description in the online parts catalog.
http://www.porsche.com/usa/accessoriesandservices/classic/classic-originalparts/originalparts-originalparts/
Mike
'83 911 SC Coupe
Old 04-29-2006, 01:53 PM
randywebb's Avatar
Old 04-29-2006, 02:25 PM
Thanks. I am not sure what the A means in front of the washer size but the 5,3 means a 5.3 mm inside diameter.
Mike
'83 911 SC Coupe
Old 04-29-2006, 03:10 PM
Just saw this thread; this key board mechanic has been fixing a heater box to muffler exhaust leak and installing an A/C system in a 911.
If there is no other information, the thread type defaults to the coarse pitch (distance from crest to crest of thread in mm): M4 is .7, M6 is 1, M8 is 1.25, M10 is 1.5, M12 is 1.75, M14 is 2, etc.
See:
http://www.metricmcc.com/catalog/Ch10/10-1005.pdf
Old 04-29-2006, 07:55 PM
Thanks Jim. That is very helpful!
Mike
'83 911 SC Coupe
Old 04-30-2006, 05:45 AM
