Brake Light Always On
81 911 SC. This is the light that goes on when you set the ebrake. When completely released light doesn't go off. Master cylinder is in good shape. No leaks. Brakes great. No drips on O-sensor. Ideas for fix?
RETIRED
Switch in ebrake handle....there's another thread talking about it.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thank. I'll search for the thread.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Hilbilly Deluxe
Recreational User
Does your cruise control work? I think the MC brake light switches are in the CC circuit.
Well I followed the links provided. I disconnected the light inside the dash and then plugged it in again. The light is now working properly. Go figure! It's been like that for a year and fixed in 2 minutes. Thanks emcon5 for steering me in the right direction.
Damn! Light came back on again.
