Throttle linkage rubbing on CV joint?
I was bleeding the clutch slave cylinder (success :)) and when I road tested the car, I heard a clicking sound as I pulled out of the parking space.
Then i felt a pulsing in the throttle pedal that increased as I increased speed. It's too late now for me to crawl back under, but could it be I bent the linkage? Can I just bend it out of the way without messing up the throw of the linkage to the throttle body? |
Yes, bend it slightly. The only thing it will do is raise your pedal a small, small fraction. Won't change the relationship to the TB.
Thanks Zeke.
| All times are GMT -8. The time now is 02:03 AM. |
