-   -   It seems I may have overfilled... (http://forums.pelicanparts.com/porsche-911-technical-forum/280337-seems-i-may-have-overfilled.html)
Carl83911 05-01-2006 09:39 AM
I posted sometime last week that my 83 SC has developed a leak. I remember that I began noticing the leak after I've topped off the oil and remembered that my oil level read at 3/4 full.
I drained a little bit of oil last friday and allowed the car to sit all weekend. I haven't noticed any leaks since.
I have someone coming over Tuesday to change the endine cooler O ring. I may have to cancel that order if it's not leaking.
Question: If i've overfilled with oil and the oil was leaking somewhere would it pool around the o ring area and eventually drip down to the heat exchangers and eventually drip on my garage floor?
I may have to just clean that area where the oil deposits have built up and see if the o rings are actually leaking.
Rot 911 05-01-2006 10:11 AM
Not positive, but I believe on the SC the airbox drain hose empties on the same side as the oil cooler. Thus if oil got sucked into the airbox it would run out on the same side of the car as the engine oil cooler.
9elf 05-02-2006 02:09 AM
I had the exact same problem.
Oil sloshes from the oil filler neck to the cis air intake just past the air filter, before the air flow sensor. From there it goes out a drain line to a spot just near the starter motor.
See the drain near the starter below.
http://forums.pelicanparts.com/uploa...1146564474.jpg
Best to keep the oil level on the low side (not below the low level mark on the dipstick though).
This has been my experience.
9elf 05-02-2006 02:14 AM
That was my black car at night.
I'll try the photo again.
http://forums.pelicanparts.com/uploa...1146564832.jpg
http://forums.pelicanparts.com/uploa...1146564877.jpg
9elf 05-02-2006 02:15 AM
Nope.
Anyway, this is what it looks like in black.
JohnJL 05-02-2006 02:57 AM
Try down-sizing the photo, that should work.
cbeers 05-02-2006 11:37 AM
For pix:
Just learned this too. I used MS Picture Manager (default for my PC) and resized (edited) the shots to the smaller "document" size and now they upload.
Hope that helps :)
-Chris
9elf 05-02-2006 01:42 PM
At risk of becoming a monotonous bore, I'll try the picture again, resized.
http://forums.pelicanparts.com/uploa...1146606069.jpg
If this is still black, please accept my apologies.
9elf 05-02-2006 02:01 PM
http://forums.pelicanparts.com/uploa...1146607301.jpg
Carl83911 05-03-2006 07:58 AM
Originally posted by cbeers
For pix:
Hope that helps :)
-Chris
I also tried attaching pics on my initial post but they were showing black. I'm using photoshop as my default.
