FI Fuel Pump?
Can you use an aftermarket perfomance fuel injection fuel pump?
Any ideas?
You might obtain responses if you were a little more specific: year and model (there are several different Porsche FI systems in use) and what your goals are.
Any help is appreciated. |
well, it'smore than just a turbo...you need a whole systematic approach. Compression of engine needs to be adressed, electronics and on and on.
tell us more about the plan and knowledgeable posters can fill you in.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Wer bremst verliert
Turbo,
The short answer is "yes, if you pick one with the right specifications." A pump rated to that HP and if the pressure range is correct should be ok. What pressure are you looking to run? What fuel management system? What injector specs? You will get help in the proportion to which you offer details, options, plans, budget, timing, who's doing the work, etc. Welcome and good luck!
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
The pump is an MSD EFI pump that should have no problem with 70 psi since I already have it on another car.
As far as fuel management and injectors, I have '78 CIS stock system. The motor has it's stock 8.5:1 pistons The Turbo is a t3/t4 off my other car since I went with a bigger turbo. I am only planning on playing with 8 pounds max of boost with an intercooler. Day to day driving with be kept at 3 to 5 psi. I'll be running a wideband to make sure my af/r's are in the right place. I have an MSD ignition and will probably change it to a msd w/ boost retard. All work will be done by me and some friends. |
Wer bremst verliert
I'd venture a guess that your pump should work just fine. I haven't done exactly what you are doing, but the pump at least should be fine.
Good luck and post pics!
Thanks John. I will post pics when I get done. Since I bought a basket case, I'm getting killed in the pocket book.
It'll all come together
